Old 28-02-17, 10:11 AM   #1
Kirkybhoy
Kirkybhoy's Avatar
Question caliper seal replacement
Need to replace the seals on the front calipers, can I do this without disconnecting the caliper from the hose ?
What should I be checking for ( hate working on brakes )
The World Is Full Of Kings & Queens Who Blind Your Eyes & Steal Your Dreams..
Kirkybhoy is offline   Reply With Quote
Old 28-02-17, 10:40 AM   #2
Default Re: caliper seal replacement
No, you need to take them off.
Clean the pistons & seal grooves, lubricate with red rubber grease. Lubricate the pad pins & the other sliding pins
Plenty of threads on here about servicing brakes
Old 28-02-17, 03:25 PM   #3
aesmith
Check there are no pits or other damage on the pistons.
Old 28-02-17, 05:32 PM   #4
Blapper
Blapper's Avatar
If you hate working on brakes, do it right. Complete strip, clean, understand what you are doing and do it yearly if you do high mileage or every two if you don't ride in rain/salt. Like maviczap said, lots of good threads on here about brakes. When you have done it once and right, next time it will be quick and you will carefully re-use the same seals.
Old 01-03-17, 08:42 PM   #5
650
650's Avatar
Follow this guide I created for the VFR750. It'll be identical on your bike if you have the 650 as they also have sliding calipers.
Very similar if you have the 1000.
Very easy job. Fill your boots:
http://www.vfrdiscussion.com/index.p...iper-overhaul/
93 VFR750 - WAY too many mods to list. Crashed
04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC
650 is offline   Reply With Quote
Old 01-03-17, 10:41 PM   #6
Kirkybhoy
Kirkybhoy's Avatar
Thanks all. New seals on order
Sent from my XT1032 using Tapatalk
Old 12-03-17, 01:12 AM   #7
Kirkybhoy
Kirkybhoy's Avatar
well that was interesting ? new piston required as one was damaged during removal... well & truly stuck in the caliper... new one arrived seals fitted piston replaced. rebuilt brakes bled... hopefully...now time to get back on.
hope I can remember how to ride it... seems like ages since I put it away for winter .
Old 12-03-17, 12:27 PM   #8
Blapper
Blapper's Avatar
Argh! I should have warned you to pump the pistons out with the lever before taking them off...
I did the same thing myself.
Old 12-03-17, 06:53 PM   #9
Kirkybhoy
Kirkybhoy's Avatar
Tried pumping piston out but it would only move about 1/4 way out. Eventually bit the bullet. Need to bleed brake again though as the lever has too much movement...
Old 12-03-17, 08:01 PM   #10
Red ones
Red ones's Avatar
Try cable tying the lever hard back to the bar overnight. Sometimes it helps release a bit of air and saves you bleeding again and it costs no time as it's overnight.
oil seal replacement sv_rory SV Talk, Tuning & Tweaking 2 25-08-11 10:56 PM
Replacing caliper seal set help Holdup SV Talk, Tuning & Tweaking 3 06-06-09 10:07 PM
Caliper seal Stu Bikes - Talk & Issues 15 20-01-09 05:35 PM
Fork Seal Replacement Luckypants Bikes - Talk & Issues 1 17-02-07 07:11 PM
Caliper Seal Kits? rscosworth SV Talk, Tuning & Tweaking 6 16-06-05 06:55 PM
