Old 22-08-08, 11:07 AM   #1
charlie13
Default Damper Rods: 99 - 02 Curvy
As it says, I would like to get hold of a pair of front fork damper rods for a 2001 curvy. Would prefer to get a set of standard damper rods, but as I'm fitting emulators I would also consider a pair of rods that have been modified.
(For modified rods they should not have extra holes drilled in the lower part of the rod, and the 4 holes in the lower part should be no larger than Ø11mm. Rebound hole in the top of the rod closed or unclosed, I can have that welded shut as required.)
thanks peeps
Old 22-08-08, 07:03 PM   #2
carsounds_dan
Default Re: Damper Rods: 99 - 02 Curvy
i have a set of forks im breaking which bit is the damper rods?
i've taken off the preload caps and removed everything down to the springs
Old 24-08-08, 01:02 PM   #3
charlie13
See the picture of the internals including the damper rods for the forks on this thread. http://forums.sv650.org/showthread.p...ulators&page=5
it's at the bottom of page 5
Old 25-08-08, 03:25 PM   #4
carsounds_dan
i have my damper rods then, i'll get them out of the forks tonight if you want them? pm me an offer.
Old 27-08-08, 04:32 PM   #5
charlie13
pm'd
do you get the damper rods out? charlie13 SV Talk, Tuning & Tweaking 11 28-08-08 12:40 PM
SV650s 1999 Curvy Damper Bolt (For Forks) Wanted cudd Stuff Wanted 2 26-08-07 08:23 PM
Damper Bolt For Fork, sv650s 1999 curvy cudd SV Talk, Tuning & Tweaking 7 24-08-07 11:03 PM
Extremetech Steering damper + fitting kit 4 Curvy SVmonkey For Sale - SV's and SV related items 5 17-08-07 06:57 PM
damper rods - loosening/tightening weazelz SV Talk, Tuning & Tweaking 11 28-09-06 12:56 PM
