Old 22-06-17, 04:31 PM   #1
Craig380
Default Best way of supporting bike to check / grease rear linkage (that isn't an ABBA stand)?
A quick question while it crosses my mind: what's the best way of supporting an SV650 to service the rear suspension linkage?
I can't hang the bike from rafters in the garage and don't have access to an ABBA stand (and can't really justify buying one as I already have front & rear paddock stands).
Is it turning the footpegs upside down & axle stands? Or can a car jack be used anywhere under the engine / frame (with a block of wood to spread the load)?
Thanks for any pointers.
Old 22-06-17, 05:32 PM   #2
Default Re: Best way of supporting bike to check / grease rear linkage (that isn't an ABBA stand)?
this. once you have turned the pegs round put an axle stand under the opposite peg to the sidestand so its touching the bottom of the peg. go round the other side and put the axle stand as near to the peg on the sidestand side as you can then 'rock' the bike up onto the opposite stand then slide the sidestand side under the peg. if you try and use the paddock stand first it wont lift the bike up far enough as the suspension is in compression.
personally i would never go back to paddock stands after using an abba stand. i have the swingarm removal bobbins permanently connected to the bike as its much better than the fitting kit. yes they are expensive but worth every penny and so easy to use and secure.
abba stand + front lift + swingarm removal kit and you can strip the whole bike on the stand if you wanted.
Old 22-06-17, 05:50 PM   #3
Blapper
Blapper's Avatar
Interesting. Hopefully I won't have to buy the bobbins for mine as I hope to not need to strip it that far.
Old 22-06-17, 09:24 PM   #4
DomP
Agree with Bibio, abba stands and the swingarm kit make maintenance so easy
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Abba bike stand ooger For Sale - SV's and SV related items 3 17-01-17 12:50 PM
Abba stand/Haynes manual/HEL rear brake line Speedy For Sale - SV's and SV related items 2 24-10-13 06:15 PM
supporting bike without stand? curvy custard SV Talk, Tuning & Tweaking 56 01-02-11 12:46 AM
Tips for unloading rear suspension without ABBA stand Luckypants SV Talk, Tuning & Tweaking 8 06-03-07 11:46 AM
Abba Bike Stand petevtwin650 Stuff Wanted 5 19-02-06 11:00 PM
