Old 26-06-17, 08:22 PM   #11
DougieG
DougieG's Avatar
Default Re: GSXR front end finished
Legend! I will get it all fitted up and see if the lack of lock bothers me first! Need to find a garage that will do it first the local suzuki said no ha
Sent from my SM-G935F using Tapatalk
DougieG is offline   Reply With Quote
Old 26-06-17, 08:24 PM   #12
do it yourself, its easy.
Old 26-06-17, 08:28 PM   #13
DougieG
DougieG's Avatar
No garage and dont know how I would get the front end kept off the ground
Old 26-06-17, 08:50 PM   #14
put a rod through the hole in the front of the engine block then put on axle stands.
i dont have a garage and i done mine in my garden. if you have all the bits it should take you a day of easy work, if you go at it it will take 4hrs.
the secret is to make sure you have EVERYTHING you need first including the tools especially the stem locknut tool.
Old 26-06-17, 08:54 PM   #15
DougieG
DougieG's Avatar
Ah stem locknut tool good point I had to borrow one when i changed my stem nut so I could use a ram mount! Did you need anything else?
Old 26-06-17, 09:16 PM   #16
its not a stem nut tool (thats just a big socket) you need the castellated socket tool to remove/install the actual locking nuts under the top yoke.
you also need a T40 security bit socket to get the ignition off/on.
tub of bearing grease. brake fluid.
i'll go check if the headstock bearings are the same. yes bearings are the same.
Old 26-06-17, 09:19 PM   #17
DougieG
DougieG's Avatar
Yeah big socket i can get, do you know where I can get the castlated one?
Old 26-06-17, 09:20 PM   #18
ebay. think it might be best to start a new thread so not to clutter this one up.
Old 26-06-17, 09:21 PM   #19
DougieG
DougieG's Avatar
Yeah sorry guys
Old 27-06-17, 06:56 AM   #20
svbmx
svbmx's Avatar
Bikes looking good, much better with the gixxer front end
Blue 99 SV650s... Naked SV/GSXR/Ducati Hybrid! Build Thread... HERE!
svbmx is offline   Reply With Quote
Front forks - to GSXR or not to GSXR? tom46 SV Talk, Tuning & Tweaking 13 23-06-10 02:27 PM
Fitting GSXR front mudguard to GSXR USD forks maviczap SV Talk, Tuning & Tweaking 1 20-02-10 10:05 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
