Old 26-02-13, 09:31 AM   #1
SV650Racer
Default Urgently needed rear caliper carrier pad retaining clip
For a customers minitwin as they want to do a trackday Friday im needing the pad retaining clip that sits as part of the caliper hanger from an injected SV650. Sadly not available from suzuki on its own.
Is the clip as part of number 14 on this photo: If you can help please message me..
Old 26-02-13, 09:55 AM   #2
SV650Racer
Default Re: Urgently needed rear caliper carrier pad retaining clip
Sorted..
Old 27-02-15, 05:21 PM   #3
JonSV
I've just replaced my rear pads and this spring clip fell to the floor in 3 pieces when I removed the pads. I'm not paying the £70+vat suzuki want for the bracket and clip, which seems to be the only way to buy a replacement.
So can I run it without the clip? The old one obviously wasn't doing much in 3 peices, and other than possibly reducing noise I can't see what the clip actually does as the pads are retained by the bracket anyway. Or can the clip be bought separately anywhere? I have googled but not found anything. Or does anyone have a spare lying around?
Thanks
Old 13-07-18, 06:25 AM   #4
steve07
Jon,
What was your resolution just run without, have a similar issue.
Steve
Old 18-07-18, 11:33 PM   #5
Yellow650Loz
Junior Member
Thanks
If it's supposed to be a piece of sprung steel that fits under the retaining pins and against the outer pad edge......you can run without it.
It's just an anti chatter plate, you'll hear more noise from the brake than usual......I've never noticed the difference personally.
If you're talking about an E clip/circlip or R clip/split pin.....or pad retaining pin then no you can't run without it
Yellow650Loz is offline   Reply With Quote
Old 30-07-18, 11:11 AM   #6
steve07
Smile Re: Urgently needed rear caliper carrier pad retaining clip
Cheers mate many thanks
Rear caliper retaining pins siezed. Jordy SV Talk, Tuning & Tweaking 16 08-11-10 07:18 PM
Urgently needed sv rear tyre sv_rory Stuff Wanted 1 30-09-10 09:38 PM
HELP... rear calliper carrier needed!! 2hys Stuff Wanted 0 21-02-10 08:37 PM
Urgently Wanted -Rear Brake Caliper Ash999 Stuff Wanted 2 20-03-06 10:52 PM
Rear Brake Caliper Retaining bolts **WARNING** derbybiker SV Talk, Tuning & Tweaking 11 07-10-04 01:00 PM
