Old 19-11-18, 02:31 PM   #6611
Adam Ef
Adam Ef's Avatar
Default Re: Gripe of the day - What is yours?
It's only ever had the weight of my SV on it. Mostly for getting the wheels off the ground in the winter. The only proper job I've used it for was doing the swingarm recently. Other than that it's sat unused in the garage for much of the past couple of years.
I noticed it looking slightly off a while ago, but seems to have got really bad now. There's cracks in the paint around the weld. Not sure what is underneath or if the weld is coming apart.
They say they guarantee them for 3 years on their website. Mine is just over 2 years old. Hoping to get a response to my email to them.
edit * Annoyingly I need to use it to swap my tyres out this week, but not sure I'm going to trust it the way it is.
Old 19-11-18, 03:11 PM   #6612
i dont think its a manufacturing defect. weld dont come apart unless they are not welded properly or force has been applied. to bend it like that its a fair old force that has been applied. my guess is someone has used it as a lever or reversed/driven a car/van into it.
have you moved recently?
Old 19-11-18, 04:56 PM   #6613
Adam Ef
Adam Ef's Avatar
Nope. It's been here since I bought it. In my garage. Either under or next to the bike. Never had anything on it apart from my SV.
Old 19-11-18, 04:58 PM   #6614
Adam Ef
Adam Ef's Avatar
Welds are usually stronger than the metal they are holding together. I did a bicycle building / brazing course a few years back and the first thing we did was weld two pieces of tube together and then try and destroy the weld. No one could do it. Everyone destroyed the tubes trying to pull the weld apart. Unclean or incomplete welds however...
Old 19-11-18, 06:03 PM   #6615
SV650rules
The weakest part of a weld is normally the heat affected zone right next to it, where the toe of the fillet meets the parent metal, the grain has been heated and cooled - can be heat treated after welding to refine the grain and make it stronger. Sometimes the parent metal can be undercut in the area where weld meets parent metal which thins the metal, the change of section between thick weld and tube concentrates stress in that area.
2016 SV650 AL7
Old 19-11-18, 06:35 PM   #6616
Why didn't I go for a ride yesterday when the sun was out, and relatively warm?
Today was bad, tomorrow is meant to be even worse
Old 19-11-18, 07:03 PM   #6617
pookie
pookie's Avatar
its a bit moist out there! It could be worse.. !
Old 19-11-18, 07:09 PM   #6618
said the fisherman to the ...........
Old 20-11-18, 12:39 AM   #6619
embee
embee's Avatar
Ordered 3 items together on Amazon. Got a message that they've sent one item first to expedite the delivery, and the other 2 will follow. Now got a message that the other 2 have been despatched. First one sent will arrive 25th, second package due to arrive 22nd.
Doh.
Old 20-11-18, 01:27 PM   #6620
Adam Ef
Adam Ef's Avatar
Still no luck getting through to Abba and no response to messages.
Mentioned it to my mechanic friend today and he has had the same happen to his. Obvioulsly his has had a bit more use being a motorcycle mechanic and it being used in his workshop. His bent at the join too. Happened gradually over time. He had it bent back to a right angle and had a gusset welded in to the inside corner to strengthen it.
I may just get that done myself rather than gettting Abba to sort it even if they do reply to me and / or offer.
whats ur biggest gripe about the uk? kwak zzr Idle Banter 101 15-11-16 06:33 PM
heated grips gripe adw Bikes - Talk & Issues 8 12-05-10 02:48 PM
