Old 05-10-14, 02:34 PM   #1
Corny Gizmo
Default idle adjuster - pointy 2014
Hi all, trying to do the tips adjustment but can't find the idle adjuster, any ideas?
Old 05-10-14, 02:48 PM   #2
Corny Gizmo
Default Re: idle adjuster - pointy 2014
I know where it should be but it's not in the left part of the frame, I'm very confused
Old 05-10-14, 03:31 PM   #3
Follow the flexible cable from the front throttle body, clip the white plastic bit back into the holder on the left.
Old 05-10-14, 03:41 PM   #4
Corny Gizmo
The holder isn't even there sid, iv got a feeling they have moved it for this model, the user manual states that if the idles needs adjusting to take it to a dealer, doesn't even mention where the idle adjustment screw is.
Old 05-10-14, 03:52 PM   #5
Nutsinatin
Nutsinatin's Avatar
I'm pretty sure the idle adjustment was ECU only from 2007 onwards, so no screw?
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 05-10-14, 04:01 PM   #6
Corny Gizmo
Nuts, take it that means I can't do the TPS adjustment then ?
Old 05-10-14, 04:12 PM   #7
Nutsinatin
Nutsinatin's Avatar
I'd wait for someone with a bit more knowledge to confirm, but I can't see why not, especially if you aren't having any idle issues, it's just an extra useful step but not vital.
Old 05-10-14, 04:23 PM   #8
Corny Gizmo
Done it anyway, idle adjusts itself
Old 05-10-14, 05:30 PM   #9
Nutsinatin
Nutsinatin's Avatar
Good to know, will be useful if I need to do my tps any time, ta.
Old 05-10-14, 11:14 PM   #10
when doing the TPS there is no need to set the idle on twin spark bikes 2007 onwards as its auto. you will however have to let each adjustment settle before making another.
K2 Seized idle adjuster. kd80 Bikes - Talk & Issues 5 15-07-10 10:51 PM
Pointy Chain Adjuster nuts, M8? lazymanc SV Talk, Tuning & Tweaking 0 22-06-09 08:25 AM
Pointy Axle adjuster - please help ! RGV250ads Stuff Wanted 1 16-03-09 10:02 PM
Idle adjuster not turning? skyline SV Talk, Tuning & Tweaking 2 05-03-09 03:06 PM
Idle Adjuster Screw mattglavin SV Talk, Tuning & Tweaking 11 11-10-07 12:37 PM
