20-06-18, 01:20 PM | #11 | |
Re: Barback Risers & Stock Cables - 2017 L7
20-06-18, 01:21 PM | #12 | |
20-06-18, 01:23 PM | #13 |
Spoke to SW Motech this morning. The only product they authorise for use on the L7 is a straight 20mm riser. No bar back and that's due to the cables. Obviously, with new cables you can fit whatever you like but I'd rather not go through the rigmarole of changing cables at the moment so I'm going to try the 20mm riser and see if that does enough. I don't need much of an adjustment so hopefully it will do the trick. We'll find out tomorrow and I'll update the thread.
20-06-18, 01:24 PM | #14 |
And why when I decided to replace my Spark plug caps I went with some Straight Race-Type NGK Plug caps
https://www.ebay.co.uk/itm/1x-Genuin...AAAOSwU~FWDPYh A pair for under 20 UK beer tokens.OEMs just under 60 Beer tokens :O
20-06-18, 09:29 PM | #15 |
Same here, please update and let us know.
21-06-18, 10:29 AM | #16 |
OK, the SW Motech 20mms installed beautifully with zero problems with the cables and they've given the exact position I wanted. Amazing how much difference that 20mm makes.
21-06-18, 11:09 AM | #17 |
Nice and all good info
21-06-18, 12:11 PM | #18 |
looks good
maybe thats why my bars sit closer to me as the cnc yoke i have the bars sit over the stem nut like yours in the pics. |
21-06-18, 12:29 PM | #19 | |
Yes, that's probably why. I'm glad I tried these as I now know that the bar back versions would have moved me back on the bike and completely thrown off my riding position. These just pop my back straight and put a small amount of bend in my arm which alleviates any stress to frame or arms. Brilliant! |
21-06-18, 12:57 PM | #20 |
you should always ride with your arms bent at your elbows even if it means leaning forward slightly. the closer you can get your forearms to horizontal the better it is for your wrists and riding.
Thread Tools | |
WTD curvy naked cables: throttle cables, choke, clutch cable . | Joe Marcon | Stuff Wanted | 7 | 14-09-12 07:21 PM |
bar risers ? where can i get some ? | barwel1992 | Bikes - Talk & Issues | 0 | 01-12-09 07:17 PM |
Clutch cables/Throttle cables Curvy | 21QUEST | For Sale - SV's and SV related items | 0 | 05-08-08 08:45 AM |
bar risers | wow | SV Talk, Tuning & Tweaking | 14 | 19-06-08 06:16 AM |
Bar Risers and cables | drumwrecker | SV Talk, Tuning & Tweaking | 2 | 21-03-06 08:34 PM |
