Old 21-06-18, 01:06 PM   #21
WightDiamond
Default Re: Barback Risers & Stock Cables - 2017 L7
Yep, which was what caused me to have to lean forward more than I wanted to.
Old 21-06-18, 02:58 PM   #22
Talking Heads
The risers you have fitted will bring the bars both up and back because the yoke and risers are not vertical
Edit: btw that's some amount of gadgetry clamped to your bars,the sort of thing I go riding to get away from....
Talking Heads is offline   Reply With Quote
Old 21-06-18, 06:21 PM   #23
WightDiamond
It's actually my phone, sat nav and the controls for the heated grips. It looks crowded from that angle but it's actually not. Some prefer to ride bare of gadgets. I like to have comms and sat nav at hand.
Old 22-06-18, 04:48 PM   #24
WightDiamond
Quick but important update: During my first ride with the 20mm risers the clutch became a problem on full (and near full) right hand lock. So much so, it would prevent the gears from engaging and was actually quite dangerous in traffic. I stopped and adjusted the cable slightly but it didn't fix the problem. When I returned home I had to removed the clip/cage from around the cables, clip of the zip ties and by doing so give the cable just enough slack for it not to pull on full lock. So whilst the 20mm does not require a new cable it does require adjustments in order to work properly.
Old 24-06-18, 12:54 AM   #25
Flybuster
Flybuster's Avatar
That's one lovely looking SV.
Flybuster is offline   Reply With Quote
Old 24-06-18, 07:15 AM   #26
WightDiamond
Cheers Flybuster!!
WTD curvy naked cables: throttle cables, choke, clutch cable . Joe Marcon Stuff Wanted 7 14-09-12 07:21 PM
bar risers ? where can i get some ? barwel1992 Bikes - Talk & Issues 0 01-12-09 07:17 PM
Clutch cables/Throttle cables Curvy 21QUEST For Sale - SV's and SV related items 0 05-08-08 08:45 AM
bar risers wow SV Talk, Tuning & Tweaking 14 19-06-08 06:16 AM
Bar Risers and cables drumwrecker SV Talk, Tuning & Tweaking 2 21-03-06 08:34 PM
