Old 02-03-15, 11:05 AM   #371
tom9
Default What have you tinkered with today?
I have fitted some new renthal soft compound grips to replace to hard heated grips which let through a lot of vibes. New grips are superb and I do recommend them to anyone thinking about new grips. Cheap too, only about £7.50.
Also given some bar end mirrors a go as they too were cheap. They are much better than I expected although it is a little odd having to move your head instead of just an eye movement. Also massively improves the aesthetics imo.
tom9 is offline   Reply With Quote
Old 06-03-15, 08:44 PM   #372
Default Re: What have you tinkered with today?
Old 06-03-15, 09:15 PM   #373
carelesschucca
carelesschucca's Avatar
I've got tinkering for you Lance
Old 06-03-15, 09:27 PM   #374
i'm hoping that Sunday will see me over at yours tinkering with you... oohhh sorry your bike..
Old 06-03-15, 09:28 PM   #375
carelesschucca
Cool you can get hugs and cuddles
Old 09-03-15, 11:13 AM   #376
TheRamJam
TheRamJam's Avatar
My front brakes where dragging a little so I took the wheel off and gave the calipers and pistons a good old clean. While I was at it i've replaced the caliper bolts, mudguard screws, pinch bolts, tank cover screws with Ti replacements. I've also ordered Ti replacements for the front brake disc bolts, rear disc bolts, sprocket nuts, and suspension linkage bolts. Fitted the GiPro too
Previous: Suzuki SV650S K9 - Sold
Suzuki GSXR1000 K8 - Wrote Aff
Honda Fireblade RR-9 - Sold
Yamaha MT 10 - Sold
Current Bike: Aprilia Tuono V4 Factory
TheRamJam is offline   Reply With Quote
Old 09-03-15, 11:49 AM   #377
atassiedevil
Sorted the 2nd VF1000F, now running properly and idling. Carb balance, and decide if i sell or keep.
Old 13-03-15, 06:25 PM   #378
gt900uk
Got these bits to get fitted, powdercoater has covered the machined section that the calipers mount to. Should I remove it or just bung the calipers on there?
Old 13-03-15, 06:28 PM   #379
admin
John T
admin's Avatar
You might need to ream out various holes with a drill bit or a tap if threaded. They do tend to get clogged.
Old 13-03-15, 06:33 PM   #380
gt900uk
All the threads are good as we discussed covering everything including the machined caliper mounts. Obviously just forgot about those but not sure how much of an issue it will be.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
