Old 11-03-10, 07:46 PM   #11
simesb
Default Re: FI light and no fuel pump whine
Stick it in dealer mode and get the error code. You can then find out what it thinks is wrong.
Old 26-06-13, 01:36 PM   #12
Lokaj
Originally Posted by Tallguy View Post
I've got something similar, in my case instead of the usual whine I get a squeak from the pump then FI.
It's doing it all the time since I cleaned it Sunday, so I have to keep retrying for several mins before I get the full zeeeeeeeeeeee instead of zikfz. If you know what I mean!It never cuts out whilst riding though, but it is annoying when it takes you ten or twenty times to get the magic noise instead of a mouse farting.
So should I do the following:
One, try wiggling and turning the key in the barrel
Two, flick the kill switch a couple of times,
Three, when I have time, strip and clean the ignition barrel an kill switch.
Or do you think I should be looking more at the fuel pump end of things?
All advice from the MIGHTY ORG appreciated thangyewverrmush.
Ps I thought it was my immobiliser, which it might be I suppose, though the zikfz noise leads me to think otherwise. Any thoughts? Abletronics something or other...
Tall guy, I am having the same issue, did you ever figure this out?
Old 26-06-13, 01:52 PM   #13
Tallguy
Tallguy's Avatar
Can't remember, though I'm sure it was something trivial like cleaning kill/ignition switches and wiggling connectors.
It worked forever after, at least til I sold the bike on here. I now GS Adventure everywhere. It's frackin' enormous, much like me.
Pointy K3S in SuperSonicSilver, R&G bungs, Carbon Can Co slip-on SOLD TO MEMBER "Cobra"! So long old friend!
I'm going all Charley Boorman on yo' ass. Can't filter or indicate any more.
Tallguy is offline   Reply With Quote
Old 06-09-18, 03:50 PM   #14
OliveOil
Thumbs up Re: FI light and no fuel pump whine
Omg, Can't believe the problem may be such a quick fix for now.
Whenever I get this problem I just turn the key on and to lock, quickly a couple of times, flip the switch like a zealot and it works !!
Now I can take my time trying to remedy / clean / order parts !!
Thanks for sharing guys!
Fuel pump not coming on. mackrilld SV Talk, Tuning & Tweaking 5 05-11-10 05:00 PM
Fuel pump problem, maybe. mudgutsdunn SV Talk, Tuning & Tweaking 5 11-03-10 11:54 PM
How do i remove the fuel pump on a K5 tonny006 SV Talk, Tuning & Tweaking 10 01-10-08 08:45 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
