Old 25-09-18, 07:27 PM   #3391
Default Re: Smile of the day - What is yours?
nice one John
we had all the mains flushed last year and since then the pressure has been a nightmare as it now runs normal then all of a sudden you get a burst of pressure which usually results in me getting soaked... lol
best water pressure i have ever had the misfortune of dealing with is in Lower Largo, when fitting a washing machine you have to install a ballafix and set it to almost fully off. turning a garden hose on results in 20ft fountain.. lol
Old 25-09-18, 08:23 PM   #3392
SV650rules
nice one John
You can get pressure reducer valve to reduce incoming pressure and maintain a constant pressure ( mount near to stop tap ), our whole house has hot and cold water ( pressurised hot water tank) at 3 bar ( 45 psi ) which is ideal and means a power shower does not need a pump.
Originally Posted by admin View Post
The front garden at Tapley Towers is in a bit of a state. The drive needed re-tarmacing so I've taken the opportunity to have the water mains pipe renewed. The old pipe has clearly been getting more and more clogged over the years.
The new pipe was connected today and what a difference to the pressure it has made. Such a small thing but it's brought a huge smile to my face.
Thank goodness houses have been fitted with plastic water pipes from water company stop tap to house for quite a while now, they don't corrode and block up and are flexible enough that they don't crack with soil movement - progress......
2016 SV650 AL7
Old 25-09-18, 08:26 PM   #3393
Heorot
I had to fit a reducer to our villa in Turkey. The mains pressure was so high that it hurt if you put your hand under the cold tap when it was fully open. The reducer brought the pressure down to a more reasonable level.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 26-09-18, 06:09 PM   #3394
garynortheast
garynortheast's Avatar
Have to go to Aberystwyth tomorrow to deliver my little portable studio to a friend for repair. Weather forecast gives wall to wall sunshine and 17°C so I think that means I'll be going on the bike then.
Old 05-10-18, 11:08 AM   #3395
its stopped blowing a gale and pizzing down. its lovely out
Old 05-10-18, 12:17 PM   #3396
Luckypants
Luckypants's Avatar
Listening to the rally cars tearing up the forest.
Old 05-10-18, 12:50 PM   #3397
zsv650s
Finally got round to ordering a kriega R30 after my old hein gericke rucksack zip finally snapped after years of faithful service.hoping it's as good as the reviews make it out to be certainly more money than I wanted to spend on a backpack.
zsv650s is offline   Reply With Quote
Old 05-10-18, 06:23 PM   #3398
kaivalagi
I have Krieger us10 and us20 bags that I bought back when they were a little cheaper, almost 10 years ago now, and they're still going strong...they may be over priced but I don't think there's anything as good out there...
Mark
Triumph and Suzuki owner
Old 06-10-18, 08:00 PM   #3399
Sir Trev
Sir Trev's Avatar
Had a day out to the coast as Lady Poppy was off seeing her dad and I could trundle around at my own pace. Took the train unfortunately as the weather forecast was carp and sure enough I got soaked after 14:30 but I had a cracking walk along the Essex coast from Southend to Shoeburyness and found quite a lot of geocaches along the way. Feel shattered now and you don't realise how sh1te the old/noisy rolling stock is on your home line until you spend the day on a more modern line but it was a nice day out.
Old 10-10-18, 06:49 AM   #3400
Bri w
Bri w's Avatar
Sat in shorts and t-shirt, cup of coffee in hand, watching the sun rise over the sea. A few clouds about, and a breeze blowing up the valley. Don't you just love life!
what made me smile kiggles Idle Banter 1 07-04-11 09:00 PM
Smile :o) Speedy Claire Idle Banter 5 07-10-10 08:21 AM
To make you smile gruntygiggles Idle Banter 7 03-06-10 12:45 PM
Smile... the_lone_wolf 2009 Annual Rideout 14 31-07-09 01:01 AM
First smile kitkat Photos 12 08-02-09 08:55 PM
