Old 23-04-09, 12:30 PM   #1
Lucas
Default exhaust Silicone/sealant anyone?
my exhaust re-engineering skills are not quite there and I got a leak
anyone got some I can pick up from soho this friday and return next?
cheers
Old 23-04-09, 12:53 PM   #2
Kinvig
Default Re: exhaust Silicone/sealant anyone?
Just pop down your local hardware store/B&Q!
Old 23-04-09, 06:30 PM   #3
BBadger
i will be needing a touch... maybe a whole tube.
Am off to get some tomorrow morrning but doutful to make a soho visit with bike in current exhuastless state.
if i do ill be sure to bring it .
Old 23-04-09, 06:34 PM   #4
mattSV
mattSV's Avatar
Agreed - cheap B&Q clear silicone sealent does the job.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 23-04-09, 07:23 PM   #5
martianskippy
I've got some spare heat resistant sealant "Fire Putty" - brilliant for exhausts. I won't be coming to Soho tomorrow (I'm having CT scan done on my leg) but you are free to swing by mine and pick it up if you need it. Just drop me a PM and I'll give you my address.
Old 23-04-09, 08:00 PM   #6
Spiderman
Where the hell am I?
Spiderman's Avatar
From pertsonal experience i can tell you that Fire Putty is tottaly and utterly crap! I too was suprised by this from a brand like Holts but it dires and goes flaky after a while where as a silicon sealant stays flexible.
Lucas...i have a tube of sealant i'll bring to soho for you tomorrow.
Old 23-04-09, 09:10 PM   #7
Lucas
Cheers all!
Old 23-04-09, 10:05 PM   #8
martianskippy
Well, it worked really well on my exhaust - mind you I used it only as an additional means to ensure the joints were properly sealed under the clamps. I wouldn't know how it would work if you used it to seal a hole..
Old 24-04-09, 02:38 PM   #9
Spiderman
Spiderman's Avatar
Thats exactly what its meant for mate, yet if you ever take the clamp off you will find its all turned into a chalky, flaky mass thats just sitting there and not bonded to either surface. Like i say i expected it to be very good but i was very disappointed to say the least.
Old 24-04-09, 02:48 PM   #10
Lucas
it some very small gaps (1-2mm) between sleeve and inlet that needs filling, so hope it works!
Gasket Sealant gettin2dizzy Bikes - Talk & Issues 5 21-04-09 07:10 PM
Justi fitted a standard exhaust. Pipe sealed with silicone. How long before I start motor? monkey Bikes - Talk & Issues 14 27-08-08 05:25 PM
What is better - Silicone goo or spray? NadineDieBiene SV Talk, Tuning & Tweaking 3 12-08-07 03:51 PM
Sealant danf1234 SV Talk, Tuning & Tweaking 4 17-02-07 11:54 AM
what solvent and sealant? lukemillar SV Talk, Tuning & Tweaking 7 11-09-06 04:44 PM
