Old 28-06-10, 09:42 PM   #11
Razor
Default Re: Tyre pressures SV650S?
so 33/36 amirite?
Old 28-06-10, 09:54 PM   #12
ave had no probs means there is a larger contact patch with road
Old 28-06-10, 10:53 PM   #13
Telford_Tim
Well i went with what suzuki say n put 36 in the back n 33 in the front n it feels a bit quicker n easier to lean the bike from one side to the other. Also rained on the way home in a big downpoor which is best described as biblical and the bike felt fairly stable so..... Thank you all for your help, another problem solved by the wise sv.org elders
Old 02-07-10, 09:33 PM   #14
mep
mep's Avatar
Originally Posted by Razor View Post
always inflate to pressures stated by tyre manufacturer
I have Avon Storm 2 Ultras and was told by my tyre fitter they should be 36 front & 42 rear. So it seems it's down to the tyre manufacturer, not the bike manufacturer.
mep is offline   Reply With Quote
Old 02-07-10, 10:04 PM   #15
Dicky Ticker
I would go with the manufacturers recommended pressure as tyres do vary in their construction.
i.e. Triumph recommend 36 front 42 rear but the new Michelin recommendation for their tyre is 34-40.
I would presume that the Suzuki recommended pressure is for the OE tyre that they fit and not the alternative you have chosen to fit
Old 03-07-10, 08:45 AM   #16
Great, that means I will be loads faster running them at 3psi.
So many more factors to it than that!
Old 03-07-10, 08:53 AM   #17
flymo
flymo's Avatar
so 33/36 amirite?
Yes, unless you are carrying a load heavier than approx 90Kg, in which case 36 front and rear.
Old 03-07-10, 10:17 AM   #18
I know YC that was the short answer.
Old 03-07-10, 10:18 AM   #19
IMO it was misleading and incomplete.
Old 19-08-13, 10:19 AM   #20
nikon70
Reviving this thread, as my bridgestone is starting to feel low/look low too... and was looking on here for rough pressure people are running.
Manufacturers rating is for the tire size, so that will be your general PSI, however riders all have a preference whether it be more or less according to rider weight, road conditions, and bike handling etc.
When you take your bike in for your service, the guys generally set your rear pressure to 34-36PSI.
No idea what mine is currently, will check tonight on way home and inflate and will feedback later. Never really filled up my tyres before, they usually get a puncture or wear out before then
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
Tyre pressures mxm35948 SV Talk, Tuning & Tweaking 13 10-09-07 04:18 PM
Tyre pressures for an SV650S K3. keithlackie SV Talk, Tuning & Tweaking 2 28-05-07 09:09 AM
tyre pressures ? DAX SV Talk, Tuning & Tweaking 20 12-12-06 09:28 PM
Tyre Pressures fizzwheel Tyres 21 26-03-05 09:04 PM
