Old 22-02-10, 10:07 PM   #1
sniff
sniff's Avatar
Default Stumpy levers.
OK second question of the night, I want stumpy leavers for the SV as standard are far too long. Can I use any other ones as I can only find clutch leaver on various sites or ones for GSX,GSF, and SV1000's
Hate long ones and need something a bit shorter.
sniff is offline   Reply With Quote
Old 22-02-10, 10:12 PM   #2
Red Herring
Red Herring's Avatar
Default Re: Stumpy leavers
Cheapest option is to do what I did, cut them off at the length you want with a hacksaw and then get the little balls on the end welded back on. I got both mine done for a tenner at a local welding firm, after a little cleaning up with a fine file and emery paper they looked original, only shorter!
Old 22-02-10, 10:14 PM   #3
Why bother with the balls on the end?
Old 22-02-10, 10:16 PM   #4
SoulKiss
SoulKiss's Avatar
Its illegal to run without the balls to protect someone if you were to clip them from sharp jagged pointyness.
Old 22-02-10, 10:20 PM   #5
just say they're still stuck in their body and send them bill for new lever 'cos they were in the way.
I thought it was MOT thing if your tester is a c*ck. What are chances any copper on side of road knows or cares?
Old 22-02-10, 10:22 PM   #6
Red Herring
Here you go
Old 22-02-10, 10:23 PM   #7
Red Herring
Pretty good round my way....
Old 22-02-10, 10:28 PM   #8
The chances that you care?
Old 22-02-10, 10:37 PM   #9
Red Herring
Depends on how motivated I am.... Some people deserve nothing but the best!
Old 22-02-10, 10:42 PM   #10
Just something else to write on the VRN next to the loud can issues and whatever else if someones wound you up then?
Is that one still applicable with handguards fitted? I have a feeling it is despite the complete feckwittery of that.
Curvy Carbs, clutch levers and brake levers 21QUEST For Sale - SV's and SV related items 2 03-03-10 11:04 AM
ASV Levers DarrenSV650S SV Talk, Tuning & Tweaking 9 10-02-09 10:17 PM
asv levers sv650nutter149 SV Talk, Tuning & Tweaking 7 18-04-08 09:38 PM
Levers rictus01 SV Talk, Tuning & Tweaking 6 25-04-07 08:01 AM
Levers Moo Ancillaries 3 09-10-04 11:37 PM
