Old 29-01-21, 10:59 PM   #1
DickP
Default Curvy cam cover seals?
Hi,
I am going to be checking the valve clearances on my 2000 SV650S. Are the cam cover seals re-useable? Are they once use only? Are they a sealant type and if so which type?
Thanks!
DickP is offline   Reply With Quote
Old 30-01-21, 12:01 AM   #2
GeorgeRYoung
Default Re: Curvy cam cover seals?
Last winter I went thru the valve check and reused the seals without problems.
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-)
GeorgeRYoung is offline   Reply With Quote
Old 30-01-21, 08:39 AM   #3
glang
They are reuseable with care as they are rubber and didnt need any sealant for the rebuild. However this does require care when dismantling as the gaskets are quite thin and can stick so are easily damaged when the covers are pulled away....
Old 30-01-21, 09:17 AM   #4
Craig380
+1 to the above. When you have the cam cover bolts removed, tap the covers with a rubber mallet or the handle of a hammer to try and free them. Then lift carefully.
For refitting, I found it useful to stick the gasket to the cover with a little bit of grease, especially around the spark plug hole but you shouldn't need sealant apart from a little smear of black silicon sealant under the round parts of the rubber half-moons, so that they seal fully against the head. Not much is needed, just a thin smear.
Old 30-01-21, 10:39 AM   #5
Dave20046
Dave20046's Avatar
I used a little https://www.amazon.co.uk/Hermetite-R.../dp/B0068PMBR6
clear silicon would do the job I imagine and you'd need to take less care avoiding red compound being visible!
I was fitting new ones after managing to smash mine in a crash so was more concerned about the two parts not being simpatico. You probably can ordinarily reuse them but the ones on your bike must be about 20 years old, I imagine the material's lost some of it's malleability .
Old 30-01-21, 11:24 AM   #6
glang
yes as I started to lift the covers I could see the gasket was stuck on different sides so got a thin screwdriver in to run round the gap releasing it all the way along. Fiddly as you have to hold the cover away about 1/2 inch and carefully maneuver the screwdriver at the same time...
Old 04-02-21, 11:00 AM   #7
Don't think I've ever fitted new ones except if someone was being very picky and wanted them!
Screwdriver in the gap is a bit of a butchers method! Try a plastic bicycle tyre lever or something... or be very careful if using owt metal
Curvy fork seals cammy SV Talk, Tuning & Tweaking 3 02-10-15 06:54 PM
Curvy fork oil seals new and unused. radicalry00 For Sale - SV's and SV related items 4 08-05-12 01:09 PM
Curvy 99-02. Fork, Dust and oil seals muzikill For Sale - SV's and SV related items 7 15-07-11 08:58 PM
blk tank cover, service manual, fork seals for 2002 kingjoe For Sale - SV's and SV related items 0 20-04-07 05:14 AM
Fork seals 2001 curvy. Blue_SV650S SV Talk, Tuning & Tweaking 2 29-03-06 06:17 PM
