Old 14-01-21, 03:40 PM   #11
admin
John T
admin's Avatar
Default Re: Sv650 wiring loom
Originally Posted by Tomjohnson View Post
Ah that’ll be why then, I haven’t earthed the battery to anything I’m just bench testing the loom, I will have to wait till my frame is built and then earth it to that.
Just to be correct there is only one earth(from the battery to the frame)?
If there is more could someone tell me please
Probably more than one, I'm guessing frame , engine, rectifier, fairing sub-frame? The wiring diagram above should show them.
Old 14-01-21, 05:05 PM   #12
Tomjohnson
Junior Member
Will I need a rectifier to make everything work as I don’t have one atm
Tomjohnson is offline   Reply With Quote
Old 14-01-21, 05:25 PM   #13
admin
John T
admin's Avatar
You need to provide volts to power the ecu etc which a battery will do until it runs flat... assuming the engine has the alternator still installed, you just need to connect that to a rectifier to keep the battery charged.
Old 14-01-21, 05:44 PM   #14
Tomjohnson
Junior Member
I have the alternator installed but don’t have a rectifier so I can’t use that but even without that the screen doesn’t light up until I put power to another plug, I will video to show what I mean
Old 14-01-21, 05:54 PM   #15
admin
John T
admin's Avatar
You'll just need the rectifier once you get this project running meantime a battery will be fine.
Old 14-01-21, 06:05 PM   #16
Tomjohnson
Junior Member
Okay brilliant I will get one at a later date, I just need to fine the earth wires for sale as that’s the problem why nothing is lighting up. If I put a wire from the negative on the battery and then to the frame the clock lights up but displays nothing
Old 14-01-21, 07:49 PM   #17
Seeker
Seeker's Avatar
Do you have the black/white stripe wire from the loom connected to the battery neg, too?
2016 SV650AL7
2023 GSX-8S
SV650 K5 naked Wiring Loom hindle8907 For Sale - SV's and SV related items 1 11-04-18 09:53 PM
1999 SV650 Naked Wiring Loom & Top Yoke Badeye Stuff Wanted 13 26-03-14 09:29 PM
Sv650 K6 wiring loom and Complete yokes louisb1987 For Sale - SV's and SV related items 0 18-09-13 12:39 PM
2x Sets of SV650 Wiring Harness / Loom cbay For Sale - SV's and SV related items 1 09-01-12 09:28 PM
Wiring Loom GSXR Carlos SV Talk, Tuning & Tweaking 0 04-09-05 01:28 PM
