Old 18-05-16, 06:23 AM   #1
edgeofmidnight
Default clutch lever switch
I have seen the wiring diagram for the removal of the clutch lever switch but something I picked up yesterday was if you remove the switch and turn 180 deg and refit, the clutch lever doesn't have to be pulled to start. My question is would it be in hi power or low power mode on the ecu whilst running if you do this as it is effective the same as bridging the wires. or will it deactivate the 1st time you use the clutch. Also can the clutch switch be deactivated wilst flashing the ECU.
Old 18-05-16, 07:08 AM   #2
Craig380
Default Re: clutch lever switch
This thread at SVRider has many of the answers: http://www.svrider.com/forum/showthread.php?t=109086
Old 18-05-16, 12:04 PM   #3
why would you want to remove the clutch switch?
Clutch lever switch bypass? Pointy rs2fifty SV Talk, Tuning & Tweaking 35 13-08-13 07:56 PM
Clutch switch or starter switch? Mark_h SV Talk, Tuning & Tweaking 7 14-07-13 11:30 PM
pointy clutch switch and clutch lever leebex Stuff Wanted 1 03-03-13 08:18 PM
Cheapo lever and clutch switch? Sparky5583 Bikes - Talk & Issues 9 18-02-13 04:51 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
