Old 15-07-20, 09:32 AM   #1
aburamjan
Junior Member
Default no pressure In rear brakes
I have an 06 sv650s. recently took the brakes off to give them a good clean and removed the pistons too. having put them back I primed and bleed the front brakes with no issues. however, the test brakes are turning into he'll for me!
I've bleed them for 3 days now and there is clear fluid with no air bubbles coming through however, upon pressing to brake lever I can see the piston move but it does not have enough force to come out enough and push the pads down, it does slow the wheel a little but I can still move the wheel with my hands when brakes are fully engaged.
what did I do wrong? am I missing something, I did have the bleed a completely dry system.
aburamjan is offline   Reply With Quote
Old 15-07-20, 10:48 AM   #2
NedSVS
Default Re: no pressure In rear brakes
You could try taking the caliper off and elevating it a little and rotate it slightly so any air bubbles will find their way to the bleed nipple. Just put something between the pads so you don't pump the piston out too far.
Old 15-07-20, 11:08 AM   #3
if fitted check that the spring pad/retainer is the correct way round, its the metal u shaped thing with fingers that push down on the pads. the longer bars on the fingers should go on top of the piston side pads. if you dont do this then the shorter bars on the fingers will jam the brake pad.
i hope that you used RRG to assemble the pistons.
Old 15-07-20, 11:27 AM   #4
Dave20046
Dave20046's Avatar
For clarification, that's rectal rubbing grease.
Old 15-07-20, 12:22 PM   #5
GeorgeRYoung
It may help to bleed the rear master cylinder at the top banjo fitting. Air tends to gather at the top.
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-)
GeorgeRYoung is offline   Reply With Quote
Old 15-07-20, 02:22 PM   #6
aburamjan
Junior Member
thanks, I'll have to give that a go.
Old 15-07-20, 02:25 PM   #7
aburamjan
Junior Member
I specifically took a picture of it before I took it off and I'm almost certain it is the right way round
Old 15-07-20, 02:28 PM   #8
aburamjan
Junior Member
when the caliper is disconnected the piston pumps out all the way no issue. once I put the caliper and pads back on it refuses to pump out enough to actually stop the wheel. however, having said that it the piston does go back in a little too easy compared to before.
Old 15-07-20, 02:29 PM   #9
aburamjan
Junior Member
thanks for that I'll have to give that a go too. any suggestions on the best way to bleed it?
Old 15-07-20, 03:35 PM   #10
GeorgeRYoung
Press on the brake pedal, loosen the brake line fitting (banjo bolt) at the top of the master cylinder (air and fluid comes out), tighten the banjo bolt then release the pedal. Repeat a few times until the pedal becomes firm. Unfortunately, this is messy, brake fluid dribbles onto the swing arm and the rear wheel, dammit!
No rear brake pressure. SV650. JimmP SV Talk, Tuning & Tweaking 4 16-10-14 10:37 AM
K6 rear brake light pressure switch. leebex SV Talk, Tuning & Tweaking 11 23-11-12 09:55 AM
Front brakes losing pressure rapidly mackemforever Bikes - Talk & Issues 14 28-08-12 09:35 PM
Rear brake pressure switch Nobbylad SV Talk, Tuning & Tweaking 2 22-08-12 04:00 PM
Rear brakes stuck on. benji106 SV Talk, Tuning & Tweaking 14 21-09-10 01:56 PM
