Old 06-11-20, 07:38 AM   #1
shiftin_gear98
shiftin_gear98's Avatar
Default Spontaneous Hazard Lights - GSXR1000 K3
Morning Org, Help.
So whilst riding to work this morning my indicator light came on the dash. I looked down at the switch and realized it wasn't on. So I wiggled it on and off a few times. Still flashing.
I found somewhere safe to pull over and got off the bike. It's now that I notice all 4 indicators are flashing. I will say at this point I have never touched the hazard light button on this bike.
So I tried wiggling that on and off too. Still on. Turn bike off - still on.
I do have a Meta alarm fitted to the bike. So arm it and disarm it. Still on.
Turn bike on still on.
Wiggle both switches on and off again, still on. Open my boot and as my brother-in-law isn't the greatest wiring expert, disconnect the rear indicators.
Fronts still on, they embarrassingly stayed on for the remaining 20 miles to work. I repeatedly wiggled both switches during this time. Still on.
So much wiggling that I now can't remember if the hazards should be on when under the hazard symbol or the dot??
Get to work turn it off, front still flashing. I am stood by the side of the bike. Try arming and disarming the bike. Still on.
Open boot, turn bike on and I can here clicking as they flash, I'm unsure at this time if it's the relay or the alarm, still flashing.
I turn the bike off and walk around it, now this is the weird bit. Not only are the front indicators flashing, but my brake light is too, as is the small bulb in the front light. Thankfully they all stop after 10 seconds or so.
Should the hazards work with the bike turned off? The switch doesn't turn them on.
So thoughts peeps - It could be any of the following, but what would you guys check first.
A relay? The indicator relay is only about 3 months old as I needed to replace it. The old one stopped working whilst I was trying to improve my brother-in-laws handy work.
I have the one from my SV, it's not an LED one, but I'll try swapping this out too.
A short somewhere?
The switch gear? - I have the one off my SV so plan to try testing this.
The alarm? - I really don't want to have to remove this - removing the one from my SV was a massive ball ache. But this one is even older - I'm inwardly crying as I think the alarm is the real issue.
I think I am going to have to disconnect the front indicator lights at lunch to be able to ride home without any flashing, and swear at it all weekend.
Actually I'm just going to tape them over with electrical tape to get me home - as there isn't much hand spare to get to the connectors, and I'd only have to connect them back up to test everything.
PS, I hate electrics on bikes.
Currently driving a Corsa....
Old 06-11-20, 01:12 PM   #2
BoltonSte
Default Re: Spontaneous Hazard Lights - GSXR1000 K3
Pretty sure when my battery was low (forgot to connect to the charger) and the siren didn't sound I could here the solenoids in the Meta unit clicking whilst it flashed the indicators.
Street triple but I imagine it would be the same.
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 06-11-20, 02:07 PM   #3
Seeker
Seeker's Avatar
On the AL7 the hazard flashers won't work without the ignition being on (or in P position). Your flashers must be getting power from somewhere that is overriding the ignition switch - if they usually flash when the alarm is triggered (in a normal situation) it suggests that the alarm is at fault.
2016 SV650AL7
2023 GSX-8S
Old 06-11-20, 02:11 PM   #4
redtrummy
Weird - I would check all the main earth connections. If you have a dickey one then voltages can be all over the shop
redtrummy is offline   Reply With Quote
Old 06-11-20, 04:19 PM   #5
shiftin_gear98
Ok so home time came, I'm brandishing a roll of electrical tape ready to cover the front ones up. But figure I'll check first.
Press alarm button, no noticeable disarm bleep, no flashing light. Bugger I'm thinking I have a long walk home ahead if it doesn't start. However it does. No flashing lights. So I test the indicators, both front ones work as they should, ok, so I open the boot. Reconnect the rear ones. They work too, all four respond to the switch. The hazard button works as it should too.
I put the electrical tape in my pocket just in case.
They worked fine all the way home.
However when I got off the bike and turned it off I waited for the alarm to arm. It never did. No bleep no flashing lights. I'm gonna put my neck on the line and say it's the alarm.
Joy, I'll see what it does in the morning as dad duty calls now.
Old 06-11-20, 06:53 PM   #6
Toooldtodie
Toooldtodie's Avatar
Alarms are a PITA.
Had a Ford Scorpio that the alarm would go off when it rained heavily (pre-Met Office Yellow rain warnings?!)
Most people ignore them when they sound and they screw up your electrics so that the bike can still be stolen, but they prevent you from making it home because they have 1. drained your battery 2. immobilised the ignition 3. prevented any ancillary electrical item on the bike working.
Hate the things... just have to rely on people's better nature and put an NRA sticker on it with the tag line, "Mine's a 30 cal" or words to that effect.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 06-11-20, 07:10 PM   #7
SV650rules
Brother just had the alarm / immobiliser removed from his VFR750 - says it caused too many problems, including preventing the bike from starting when he wanted it to.....
2016 SV650 AL7
Old 06-11-20, 07:47 PM   #8
Toooldtodie
Don't blame him! Never had an alarm actually prevent a theft of anything of mine. Two burly blokes chasing after the thieving scrotes did get my bike back however...
Old 07-11-20, 12:26 PM   #9
shiftin_gear98
Well my bike now starts without even attempting to disarm the arm. I guess the alarm is dead.
I imagine it'll screw me over soon.
Old 07-11-20, 12:47 PM   #10
R1ffR4ff
R1ffR4ff's Avatar
I agree about alarms. They aren't a lot of use if you are away from the bike. I can give a cheap alternative though. If you have an old Android phone and it will accept this free app,
https://play.google.com/store/apps/d...focus&hl=en_GB
I have one with a spare ASDA PAYG Sim card in it and set up to be silent but send me text if the bike is disturbed. I use it when out shopping/parked and just stick it under the rear seat. If GPS is enabled on the phone it will send location as well as a cheap,"Tracker" plus if for some reason you have broken down and your main phone is not working for whatever reason you have a backup phone
Hazard warning lights not working. DanSp Bikes - Talk & Issues 5 11-01-14 05:54 PM
Cut Out / Hazard Warning Lights Mallet43 SV Talk, Tuning & Tweaking 2 29-10-09 02:01 PM
permanent hazard lights. oops I am a fool Quiff Wichard Bikes - Talk & Issues 12 11-06-09 08:24 PM
Weird indicator fault - they became hazard warning lights RingDing SV Talk, Tuning & Tweaking 5 24-01-09 09:05 PM
hazard lights flashing on duel carrage way BIKER-DENE Bikes - Talk & Issues 2 17-04-06 11:26 AM
