Old 17-06-15, 08:27 PM   #1
smudg
Default cams
Hi guys thanks for the ad im racing a sv650 this year every one tells me to put injection cams in to my carby. I have managed to pick up a set my question is, is it a straight swap ie same timing marks ect or are there any detailed threads here many thanks
Old 17-06-15, 08:32 PM   #2
Default Re: cams
Follow this guide and its straight forward
http://www.bayarearidersforum.com/fo...d.php?t=154847
Old 19-06-15, 08:43 PM   #3
smudg
Default Re: cams
thanks mav gona attempt it this week end will let ya know how it goes
Old 19-06-15, 09:16 PM   #4
PhilSV
PhilSV's Avatar
Default Re: cams
Snap, Im doing it at the moment as well
PhilSV is offline   Reply With Quote
Old 19-06-15, 10:22 PM   #5
nutzboutbikes
Default Re: cams
Philsv I believe this is called cheating!
Old 20-06-15, 08:12 AM   #6
PhilSV
PhilSV's Avatar
Default Re: cams
Just a little nip and tuck in old age !!
Old 25-06-15, 07:24 AM   #7
PhilSV
PhilSV's Avatar
Default Re: cams
How did you get on smudge?, got mine done on Tuesday, just stripped and cleaned the carbs and should be running sweet for the weekend.
Old 25-06-15, 02:41 PM   #8
jambo
jambo's Avatar
Default Re: cams
Just a heads up. In Minitwin regs you can swap curvy for pointy cams, but not fit intake cams into the exhaust as per the BARF thread. Fine for the road though.
Curvy cams are labelled A,B,C,D I believe POINTY are labelled F,G,H,I
Jambo
SV IN cams Christian525 Stuff Wanted 0 02-10-12 06:47 AM
fitting cams kev#65 Mini-Twins 6 29-10-09 08:52 AM
Web Cams Speedy Claire Idle Banter 31 14-01-09 09:24 PM
K3> exhaust cams for sale, also carbed model intake cams northwind For Sale - SV's and SV related items 0 14-09-06 11:04 PM
SV 650 CAMS wanted K3-K6 injector pointy cams wanted alien19779 Stuff Wanted 3 09-03-06 07:01 PM
