Old 14-11-18, 02:15 PM   #1
jmitch26
Default AL7, 2017 smoking from radiator
Heavy rain the other day, usual commute through London - I got some real heavy white smoke (probably rain burning through the rad?) from the radiator and it absolutely stunk.
Got told several times "YOUR BIKES ON FIRE". It was pretty heavy rain, but nothing monsoon-ey.
Anyone had this?
Old 14-11-18, 02:51 PM   #2
jmitch26
Default Re: AL7, 2017 smoking from radiator
Originally Posted by Seeker View Post
Do you have a fender extender? Most modern bikes have a ludicrously small front mudguard for our climate.
Searched it, couldn't find anything on the AL7. Not much difference I suppose to the old style SVs.
Sadly no, I've noticed I definitely need a rear fender too, my **** and seat are literally filthy. Next on the shopping list.
Old 14-11-18, 03:05 PM   #3
they all do it.. its water evaporating off the rad due to the heat. looks worse during the winter months as its ermmm colder.
Old 14-11-18, 03:51 PM   #4
It's to balance out your visor so that you have steam on the inside and outside.
Old 14-11-18, 03:57 PM   #5
Old 16-11-18, 12:17 AM   #6
Gordon13
Junior Member
I'm considering a mudflap to the bottom of my fender extender it's a pig in anything heavier than drizzle
Gordon13 is offline   Reply With Quote
Old 16-11-18, 07:36 PM   #7
SV650rules
You could try a bit of astroturf inside the mudflap - cheap to buy a doormat made of it an cut some off
2016 SV650 AL7
Old 18-11-18, 07:08 PM   #8
SVSte
Mine does the same in heavy rain not a problem as above steam from the rain.
Old 18-11-18, 07:13 PM   #9
SVSte
@Seeker that header pipe is so clean mine as turned a brown colour but will clean up a bit.
Old 19-11-18, 07:57 AM   #10
Craig380
Harpic Max Power toilet cleaner, a quid from Tesco. Paint it on with a brush, leave for 5 minutes, rinse off & polish. Job's a good 'un.
Edited to add, it's this stuff: http://www.harpic.co.uk/products/toi...ners-original/
Smoking radiator chrishaw69 Bikes - Talk & Issues 3 24-03-10 05:51 PM
