Old 20-04-17, 12:42 PM   #101
R1ffR4ff
R1ffR4ff's Avatar
Default Re: My first pointy
Originally Posted by garynortheast View Post
The cable I use would be too short for anything other than clip ons. The bit that makes the difference is the bend/tube. Strangely it's more of a curved right angle than the big arc of the oem cable. It results in a much more compact routing of the cable in the cockpit part of its run. May well be worth having one specifically made for you.
OK.Thanks for the info
Old 21-04-17, 11:33 AM   #102
Taipan
Taipan's Avatar
Well looks like the general setting up has paid off in the economy dept. By balancing the TBs, fixing inlet air leaks, cleaning air filter and fitting new plugs and caps etc the MPG is improving by the tankful.
Old 21-04-17, 01:37 PM   #103
R1ffR4ff
R1ffR4ff's Avatar
From 38 to near 50 Mpg is a helluva boost back
As always it's not usually just one component causing a problem but lack of general maintenance in a whole system.I check these things quite often over a year and also tyre pressures.
Before I changed jobs and got into Aircraft maintenance one of my early jobs was as a tyre fitter so it's a kind of legacy thing with me as I know just how much running tyres too high or to low can affect things
differences between the naked pointy and faired pointy nickodemon SV Talk, Tuning & Tweaking 19 14-07-15 08:21 PM
Rear brake calliper with axle mount for pointy Sv650 pointy nikon70 For Sale - SV's and SV related items 0 18-04-15 06:11 AM
Swap a set of Pointy wheels for a Silver Pointy front wheel Berlin For Sale - SV's and SV related items 4 13-03-11 07:35 AM
Naked Pointy brake lever fit Faired Pointy? tj ready SV Talk, Tuning & Tweaking 2 09-07-10 07:37 AM
