Old 04-02-17, 09:40 AM   #1
aesmith
Default New to me Pointy SV - what's worth doing right away?
Hi,
I've just collected an almost mint fully faired SV650, very low mileage. I'm not going to start using it until late spring so before that I want to address some of the weak points that cause trouble if neglected. On my list ..
- Grease head bearings, check adjustment
- Clean out and re-grease rear linkage
- Remove swing arm, shim, re-grease (fit grease nipples?)
- Worth rebuilding callipers right away?
What else? Anything that's just worth removing and refitting with anti seize on the fasteners just in case?
Thanks Tony S
Old 05-02-17, 08:12 AM   #2
Blapper
Blapper's Avatar
Default Re: New to me Pointy SV - what's worth doing right away?
Definitely do the calipers. Low mileage doesn't mean they are fine.
Oil and Filter (now - let it sit with new oil not dirty oil).
Old 05-02-17, 09:09 AM   #3
aesmith
Cheers. Forgot about oil but that's a good point. I forgot ask when it was last done. I have oil and filter in stock so can do that today.
Old 05-02-17, 10:12 AM   #4
Craig380
I'd have a check of the coolant, if it's looking a bit mucky and old then change it and it won't need doing again for a few years.
I'd definitely change brake fluid front and rear, grease the slide pins nicely and clean crud from the calipers. Not sure I'd do a full brake strip to change the seals yet, but I am a lazy ***.
Old 05-02-17, 11:46 AM   #5
bigup
Whilst you have the calipers off, think about changing the brake lines (they are meant to be changed every 4 years I think ) and of course fresh brake fluid
bigup is offline   Reply With Quote
Old 05-02-17, 12:06 PM   #6
aesmith
If I'm touching the calipers I might as well pop the pistons out, clean everything and reassemble with suitable grease. Get them before there's any corrosion starting in the grooves.
Old 05-02-17, 12:09 PM   #7
bigup
For the costs of new seals, I'd replace them on the calipers.
Give them a proper overhaul.
Red rubber grease is what you need for the pistons, seals and anything that touches rubber boots.
Old 05-02-17, 02:20 PM   #8
aesmith
I've always used silicone grease, it's a bit more slimy and easier to make sure it's got into the bottoms of the grooves. It's completely inert and doesn't harm the seals or other rubber parts.
Old 05-02-17, 02:33 PM   #9
be careful which one you use, i found the clear type dries out quickly.
i got some white ptfe/silicone stuff off ebay which is good and i use this on forks but i still use RRG for callipers.
http://www.ebay.co.uk/itm/200g-Silic...EAAOSwVFlT0lGf
Old 05-02-17, 02:47 PM   #10
aesmith
Cheers. My silicone grease originally came from the labs, used on O rings for instruments etc, but I'm now running out so will need to source more sometime soon. I have some "Turbo Gel" which is synthetic teflon grease used for odd items on the boat (the innards of the sea toilet for example), however I've not tried that on internal brake components.
What's it worth? Pointy DarrenSV650S SV Talk, Tuning & Tweaking 15 04-05-14 08:15 AM
What's a complete pointy front end worth? chris c SV Talk, Tuning & Tweaking 4 24-08-13 08:11 PM
Whats my pointy worth? bigspud Bikes - Talk & Issues 2 12-08-12 08:29 AM
Whats it worth - K3 Pointy. seedy100 SV Talk, Tuning & Tweaking 1 27-04-09 07:39 PM
What's an SV pointy front end worth? Lozzo SV Talk, Tuning & Tweaking 7 11-07-07 09:24 PM
