Old 05-02-17, 02:39 PM   #1
aesmith
Default Anyonen had a stuck oil filter recently?
Hi,
I'm referring to the conventional spin-on oil filters that almost everything uses nowadays. Until recently I've never had trouble removing one, normally they can be undone by hand or occasionally I use a rubber strap wrench to get them started. Now suddenly I've had two in a row that simply didn't want to shift. Completely different engines, one was the SV and one a marine diesel engine, both originally fitted by hand by me. When I say these didn't want to shift I mean they were seriously stuck. The rubber wrench couldn't shift them, and using a chain wrench the cannister was actually buckling and splitting before the base would move. Even stranger they were both almost as stiff after I'd got them undone by 1/2 a turn or more.
Just wondering if they've started making the seals of a different material recently or something.
Anyone had similar, and any tips for removing seriously stuck filters?
Tony S
Old 05-02-17, 02:45 PM   #2
Default Re: Anyonen had a stuck oil filter recently?
get a socket type. cheep and very good. wouldn't be without mine. i also have a snapon band type wrench that is good.
Old 05-02-17, 04:30 PM   #3
aesmith
Cheers, just ordering one ready for next time with the SV. Even when they undo easily, it'll save burning myself on the exhaust. I used one with the CBR for exactly that reason, but sod's law that's a different size. I'm not sure it would have shifted that filter though, suspect it would have just rounded off or crumpled the cannister.
Need a better strap wrench as well.
Old 05-02-17, 05:23 PM   #4
bigup
I use one of these and it's not failed me yet
https://www.amazon.co.uk/gp/aw/d/B00...P2L&ref=plSrch
bigup is offline   Reply With Quote
Old 05-02-17, 05:35 PM   #5
Tonka22
Funny enough, I had exactly the same problem yesterday. I can't remember how many spin on oil filters I have changed but it must be dozens. Yesterday on my SV650 I couldn't believe how tight the oil filter was. I had to stab the xin thing to get it off. Correct me if am wrong but I have always understood that oil filters only really need to just over hand tight!
Old 05-02-17, 05:50 PM   #6
aesmith
Yes I tried stabbing a screwdriver through the filter, however all that did was tear the metal and bend the screwdriver. Ended up having to cut a notch in the rim and tap it with a drift to get it started, after that the chain wrench shifted it 1/4 turn at a time, each 1/4 turn moving onto an undamaged part of the cannister.
Absolutely correct about hand tight, but these were both fitted by hand originally so I can't understand why they were such a bear to remove.
Old 05-02-17, 05:59 PM   #7
Tonka22
Yes, that's exactly what happend yesterday. Stabbed it, tried to turn it and the screw driver just ripped its way through the filter. Eventually snapping the screwdriver! Had to use a bigger 18" long screwdriver to shift the xin thing!
Old 05-02-17, 06:11 PM   #8
Red ones
Red ones's Avatar
It will be easier to take the filter off cold.
Old 05-02-17, 06:12 PM   #9
Tonka22
It was cold!!
Old 05-02-17, 06:16 PM   #10
aesmith
I always feel the oil doesn't drain properly if you do it cold.
Sent from my Nexus 7 using Tapatalk
Haven't been on here recently. Felix_ Photos 10 03-08-12 09:39 PM
What U-turns have you done recently? Nobbylad Idle Banter 13 27-10-11 07:37 PM
Done anything silly recently? Jayneflakes Photos 16 18-09-11 07:49 AM
Hobby - have you taken one up recently? Miss Alpinestarhero Idle Banter 55 09-07-09 05:24 PM
Not been recently. REEVESIE Soho Massive 2 02-12-05 12:05 AM
