Old 28-04-18, 08:36 PM   #1
bigup
Default Oil change by Mileage or time ?
Sorry for another oil change thread.
I was just curious, I know the oil interval for an sv is 3500 miles, but does this also include the OR 12 months too?
I’m coming up to a year since my last oil and filter change and not done many miles since then (Bike sat in garage most of the time).
shall i change the oil ?
bigup is offline   Reply With Quote
Old 28-04-18, 08:45 PM   #2
SV650rules
Default Re: Oil change by Mileage or time ?
Personally I would not leave oil in engine for more than 12 months - short journeys tend to be hard on oil if it never gets hot enough to boil off acidic water from combustion it can cause corrosion in the engine, but no need to change filter, just change the oil - makes the job a bit easier.
2016 SV650 AL7
Old 28-04-18, 09:28 PM   #3
bigup
Thanks. Will get some oil ordered then
Old 28-04-18, 09:36 PM   #4
Talking Heads
Also worth changing brake fluid and coolant at two years irrespective of mileage.
Talking Heads is offline   Reply With Quote
Old 29-04-18, 07:19 AM   #5
Craig380
Several oil suppliers on eBay like Opie Oils usually have offers of around £20 for 4 litres including delivery, I've been getting Shell Advance AX7 for the past couple of years at that price and it's delivered within 2 days of ordering.
Old 29-04-18, 08:22 AM   #6
R1ffR4ff
R1ffR4ff's Avatar
All of the above and I've been using Smith and Allen Motorcycle oil in my 1999 Curvy.£19 for 5L delivered to the door.Been excellent so far
https://www.smithandallan.com/produc...emi-synthetic/
Old 29-04-18, 08:39 AM   #7
yokohama
I use the Smith and Allen too; fortunately I live close enough to pick it up.
Changed the oil and filter in the SV every year. It doesn't cost much and helps look after the engine.
Old 29-04-18, 08:44 AM   #8
R1ffR4ff
R1ffR4ff's Avatar
Wow!You lucky B
You must get it dead cheap?
I had Motul MA2 in the bike and that was fine but the Smith and Allen is even smoother and my gears and clutch are as slick as hell and my engine,for 20k,is very smooth and pretty quiet
Sound clip.
https://app.box.com/s/50v1t40uzq6mayvxq6edm7cavzd3nxk6
Old 29-04-18, 09:51 AM   #9
SV650rules
Brake fluid yes, as it absorbs moisture.
Modern coolants are good for at least 5 years, the OEM coolant in cars is good for 10years before it needs replacing. The ethylene glycol anti-freeze part does not wear out as such. the limit on life has always been the corrosion inhibiting additives, with modern Organic acid and hybrid organic acid additives ( OAT and HOAT) I am happy to leave them in a bike 5 years.
2016 SV650 AL7
Time for a Change? SV400Rob Bikes - Talk & Issues 4 11-06-14 07:03 AM
Time for a change? Dicky Ticker Bikes - Talk & Issues 34 08-03-12 12:46 PM
Service query, mileage or time? cluffy SV Talk, Tuning & Tweaking 3 23-02-11 12:46 AM
Oil change time. DaveP SV Talk, Tuning & Tweaking 9 10-06-09 01:54 PM
Time for a change..... nickj Bikes - Talk & Issues 12 23-04-06 08:35 PM
