Old 07-05-14, 07:59 AM   #41
Falconbobb
Default Michelin Pilot Road 3's
Had pr2's on sv1k for 13,000 miles. Rode hard felt every pebble in the road never slipped till the last 1000 miles.
Mounted PR4's rhis year and love em. Much smoother ride sticky turn in is neutral and easier w less push on the bars. Me likes.
Old 07-05-14, 12:38 PM   #42
Default Re: Pilot Road 4
how the fek to people see high mileage out of tyres, i'm lucky to see 6k out a rear and 9k out a front.
Old 07-05-14, 12:53 PM   #43
Matt-EUC
Matt-EUC's Avatar
Default Pilot Road 4
Very smooth conservative riding. It helps if you're not very heavy.
Ad eundum quo nemo ante iit - Ad infinitum et ultra
White 650 V-Strom
-No mods
Blue curvy 650 (OMFG I FIXED IT!!!)
-200mm Delkevic Stubby.
Matt-EUC is offline   Reply With Quote
Old 07-05-14, 06:17 PM   #44
Purity14
Im 15stone in my leathers, i get 15k minimum out of a rear pr3. Both my sv650 and my cbr6.
I dont hang around, there are plenty of brutal launches, high speeds as well as country roads, and thats just on my commute..!
Old 07-05-14, 07:00 PM   #45
DJ123
DJ123's Avatar
you live in Scotland where the roads are made out of Sandpaper. Higher wear rate than smoother asphalt roads.
BMW F800ST
Old 07-05-14, 07:52 PM   #46
Nutsinatin
Nutsinatin's Avatar
Don't stop when it gets square, change it when it looks like a car tyre! Use as much of the side as possible in the spring/summer/autumn so that you can use the centre in the winter. Also in winter the wear drops drastically as the constant layer of water stops the tyre from making contact with the road! Push the front harder to save rear wear so they wear at the same rate, replace only when the centre is bald and the shoulders 1mm in the summer when it's not raining (2mm shoulder 1mm centre if it's wet!) That should be good for 14K with a pillion and loaded top box for a few thousand miles. And be smooth and fast, not ragged and fast. Works for me anyway! Be interesting to see the effect a restrictor has on this too!
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 12-05-14, 04:49 AM   #47
BanannaMan
BanannaMan's Avatar
Have had a few sets of PR-2's on the SV and absolutely loved them but time to move on.
Can get a set of PR4's for not too much more so got a set ordered. Hope to get them on the bike next weekend.
...Bill
Old 12-05-14, 04:39 PM   #48
if they are anything like the PR3's you will love them Bill. i couldn't get on the the PR2's but the 3's i'm absolutely in love with.
Old 19-05-14, 01:02 PM   #49
NTECUK
NTECUK's Avatar
Originally Posted by Minty101 View Post
Hello boys and girls so like I said had race school today I used the pilot road 4 was really cold track i mean cold 1st session of 20mins was wetter than a otters pockets tyres was pretty good everyone else was running wets so I tip toe around track (was brands Indy ) 2nd ses was dry line but still but wet so I pressed on wow t30 psi ell you what I was impressed 3rd session was dry as you like I was full lean well 80% the track was keeping up with other sv on super corsa I had them in tyre warmers for about 30Mims before sessoin 2 ,3 they was colder when I came in people had the same problem with the supers as for the 3rd ses tyres did a epic job I will be using them again for cold dam day maybw even cold dry to I ran 30psi hot front 28psi rear hot was going a 2 psi increase from cold but if you want to run this on the road I say run 30 30 cold for the road hope this helps
Sent from my HTC One using Tapatalk
30 seams very low.
I'm running 36 cold on the M5 's on the daytona and wear the edges in the classic scallop /cupping pattern.
Maybe it's ridding it to slow or not enough lean?
Old 19-05-14, 01:07 PM   #50
Matt-EUC
Matt-EUC's Avatar
I'd have to agree. I think the pressures from cold are 36 rear 33 front.
Sent via the medium of interpretative dance.
White 650 V-Strom
-No mods
Pilot power vs pilot road James SV Tyres 30 18-05-09 10:20 PM
Michelin Pilot sport vs Michelin pilot road Dave The Rave Bikes - Talk & Issues 26 08-10-07 12:19 PM
Pilot Road 2 tomjones2 Tyres 0 14-03-07 02:31 PM
Pilot Power or Pilot Road? mario Tyres 3 06-10-06 03:45 AM
pilot road raymond smith Tyres 2 16-01-06 12:32 AM
