Old 04-05-18, 01:48 PM   #1181
ophic
ophic's Avatar
Default Re: What have you tinkered with today?
I'm gonna carry on blaming the bike. Or the traffic.
Silver SV650SK3, Fuel exhaust
Old 04-05-18, 02:00 PM   #1182
Red ones
Red ones's Avatar
Originally Posted by R1ffR4ff View Post
I don't suppose you chronicled the job?Reason I ask is I've just fitted a Wemoto ,"Slinky-Glide" clutch cable and noticed a little of slop in part 17 on here if that's what we are talking about,
https://www.suzukipartshouse.com/oem...8b51089/clutch
I've no problems at the moment but might some time fit a new one.
Also as far as Clutch Lever switches go the one on my 99 has been shorted/disabled before I got it.I did the same on my old Hondas and never missed them.
It's easy enough to do. But remember to check how the old lifter was put in - they can come apart but have 3 or 4 ways they go back together, so its worth looking to see how it was before!
Loosen off the clutch cable fully and then undo the two bolts that hold the lifter in place. You may need to use some pliers to get the cable out of the old lifter, just be careful you don't damage the cable.
Pop the cable in the new lifter, bolt it on with the two bolts and then do a full clutch cable adjustment as normal. The adjuster screw on the new lifter will probably be wound a long way out.
It really is that easy.
Please resist the urge to pull the rod out of the clutch housing - its a wet clutch and you dump oil if you do that.
Whenever I do anything on the clutch adjustment I always check and adjust the chain too.
Old 04-05-18, 02:01 PM   #1183
garynortheast
garynortheast's Avatar
I always found the standard clutch cable on my curvy S made the clutch very heavy. On one occasion the nipple at the lever end of the cable gave way, so I had a look at the various old cables I have in my garage and found one off of my old GSXR GK71F which was a perfect fit. Despite the metal conduit at the top of the cable being a sharper bend the clutch was suddenly really light to use, and as a bonus the cable no longer touched inner fairing/dash.
It's this one.
Old 04-05-18, 02:03 PM   #1184
R1ffR4ff
R1ffR4ff's Avatar
Thanks for that.I have already had that number 17 off when I first got the bike and did the,"Clutch Mantra" and greased it up.It's still operating fine but I like to be pre-emptive on some things
Old 04-05-18, 02:04 PM   #1185
Red ones
Red ones's Avatar
Never had a serious problem with the cable being too heavy (maybe I have a strong left wrist)
I do (very occasionally) lube the cable though with a PTFE lube.
I find lube works well with anything stiff.
Old 04-05-18, 02:04 PM   #1186
R1ffR4ff
R1ffR4ff's Avatar
It's this one.
Nice one
So it would be one of these?
https://www.ebay.co.uk/sch/i.html?_f...cable&_sacat=0
and I see they have a protective gator
Old 04-05-18, 02:09 PM   #1187
R1ffR4ff
R1ffR4ff's Avatar
I love the smell of GT85 in the Morning
Old 04-05-18, 02:50 PM   #1188
garynortheast
Nice one
They look like the ones. Don't forget though that I'm talking about the S model curvy here. The naked curvy will have a longer cable, in which case it may be worth investigating the 400 bandit cable.
Old 04-05-18, 06:30 PM   #1189
It's this one.
I can see a modification coming up, as in town traffic my clutch hand gets sore quite quickly, even though my curvy has quite a light clutch, but I have puny hands and arm muscles
Old 04-05-18, 09:17 PM   #1190
garynortheast
Let me know how you get on with it Mav, if you make the change. If I remember correctly the cable I used wasn't one of the Slinky Glide ones but an original Suzuki cable. It's been on there for a couple of years now I think.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
