Old 01-02-16, 09:01 PM   #671
Default Re: What have you tinkered with today?
Aye, nothing like having 18 inches in the ground
Old 01-02-16, 09:30 PM   #672
Sir Trev
Sir Trev's Avatar
I've had mine for at least 14 years, this is as close as I could find in the current catalogue. I noticed there others just above it in price that have higher rated motors, so they might be better?
http://www.screwfix.com/p/energer-en...230-240v/63303
Looks identical to mine, right down to the cheap plastic case. It's a typical (probably made in China) mass produced with lots of different badges jobbie. Haven't broken a bit yet but I'll bear your experiences in mind and take more care next time.
Old 04-02-16, 09:19 PM   #673
DomP
Not sure if this is a strictly bike tinkering conversation? I've been putting new inner tie rods on my Clio 182, what a horrible pokey job! I'd rather work on a bike in a nice dry garage than a car on axle stands in the wet!
DomP is offline   Reply With Quote
Old 07-02-16, 01:32 PM   #674
Ch00
Ch00's Avatar
Changed the front brake pads on the Focus. Done bit and bobs on the bikes for years but never worked on a car before. Felt good!! (and saved a few £££)
Ch00 is offline   Reply With Quote
Old 07-02-16, 07:45 PM   #675
Kenzie
Kenzie's Avatar
It does doesn't it? Over the last couple of months I have done disc and pads, pair of control arms and link rods on the Civic
Sent from my Kindle Fire
Old 07-02-16, 10:09 PM   #676
TSM
The Sick Man
TSM's Avatar
Today I have mostly been doing a crap job of fibreglassing the 675 fairings on my SV, note to all, do not use micron pipework as it hangs lower and so job needs to be done to make it work, ffs. The way I fitted the fairing means that the front cylinder pipe routes about 5cm lower than the bottom of the fairing. It looks like a proper botch job.
Ive also made a brilliant (as in good enough) job of spraying panels black.
Changed rear brake pads on ZX, oiled throttle cables.
ps. I hate fiberglassing
Old 07-02-16, 10:10 PM   #677
admin
John T
admin's Avatar
Messy stuff.
Old 14-02-16, 09:42 PM   #678
yokohama
MOT is due before the end of the month so checked everything over today. Also took the front calipers off , cleaned the pistons and pads up and made sure the disc bobbins were all moving freely. I wanted to take the suspension linkage out and check that too but couldn't shift the bolt that attaches the dogbones.
All done while trying to dodge the hail and snow showers. Wish I had a garage ....
Old 15-02-16, 09:30 AM   #679
Corny Gizmo
Last two Sunday's of work...
Last Sunday I did my long overdue rear pads, safe to say I got my moneys worth!
And then yesterday I finally got the Loobman auto chain oiler on, first I degreased the chain with Parraffin and cleaned the whole bike. I found the only real place to mount the tank was behind the left passenger footpeg, using engine oil with a pull out spout it is easily re-fillable. The instructions for this thing make it look daunting but once I had done it, it all made sense.
In the next couple of weeks I'll be servicing her and then she needs new tyres too!
Old 15-02-16, 12:01 PM   #680
Trev B
Trev B's Avatar
Corny Gizmo,them new pads look like baby tortoises to me,just cruel cos they should be still hibernating at this time of year !!!
Somewhere up north,Never regret something that once made you smile!!!
Trev B is offline   Reply With Quote
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
