Old 12-12-05, 12:16 AM   #1
rob13
Default servicing schedule
I think this was covered a month or so ago but was part of the lost data. Wondered if someone could post up what is done at each service? Mine is due its 8k service and im not sure whether to do it myself or take it to a dealer. I can change oil/pads/filters etc but not sure on valves etc.
Old 12-12-05, 01:26 AM   #2
hall13uk
ok in my k4 sv650s manaul
it says....
Replace fuel hose every 4 years
replace engine cooliant every 2 years
replace brake hose every 4 years
replace brake fluid every 2 years
first service== 600miles or 2 months
tighten exhaust & muffler bolts,
replace oil & oil filter
tighten chassis bolts & nuts & inspect all other parts.
second service== 4000miles or 12 months
replace oil
inspect all other parts & lube as necessary
third service== 7500miled or 24 months
repace spark plugs
replace oil
tighten chassis bolts & nuts lube as necessary
fourth service== 11000 or 36 months
replace air cleaner element
inspect & lube a necessary
fifth service== 14500 or 48 months
replace spark plugs
replace oil
tighten cassis nuts & bolts
inspect & lube as necessary
copied from the SV650/s owner's manual, suzuki motor corporation many thanks.
HTH james
Old 12-12-05, 10:33 AM   #3
empty
On top of that, it's probably worth changing the fork oil at either the 8k or 11k service, and if you are doing it yourself, removing any bolt that you are ever likely to need to remove during later services and grease them, leaving them over winter means they will corrode and be much harder to get undone (trust me on this one...). It won't do any harm to replace the filter every time as well, even though the official schedule says you don't have to, putting clean oil into a dirty filter somehow doesn't seem right.
At every service check condition of spark plugs and gap. I also check the air filter housing, to make sure the two crankcase breathers are not leaking too much oil (have replaced crappy spring clips with jubilee clips).
At 15K you'll also want to check valve clearances, and I'd be re-greasing all the suspension linkages by now as well.
Cheers,
MT
Mark T
Eagles may soar, but weasels don't get sucked into jet engines.
empty is offline   Reply With Quote
Old 12-12-05, 05:36 PM   #4
rob13
the bike has actually only done 4k but is 2 years old. It had its 4k service last November
Old 12-12-05, 07:35 PM   #5
Stig
2 years old and a grand total of four thousand miles
Old 16-12-05, 10:38 AM   #6
21QUEST
21QUEST's Avatar
..so what do you say about this SV1000 I know of. Two years plus with only 1000 miles . The owner has vowed to sell get rid of it if he does not put a few more miles on it next summer .
Ben
Nemo me impune lacessit.
Old 17-12-05, 12:23 AM   #7
rob13
I know Big Ape its shameful, especially considering that only 1500 miles have been covered this year. A mix of things really, which would take too long to explain, however im going onto shift work in January, which means ill be getting plenty of time to myself midweek - ideal for getting out on the bike. Watch this space....
Old 17-12-05, 08:12 PM   #8
RandyO
the inportant things that a lot of people forget or don't take seriously are lubing the lever pivot bolts, and cables, clean & lube shift linkage
these things are just as important as changing the oil & filter, plugs, carb syncn air filter, etc.
Service schedule? DaveP SV Talk, Tuning & Tweaking 8 03-02-09 03:41 PM
SV service schedule baggies666 Bikes - Talk & Issues 4 18-09-07 07:14 PM
AE07 Schedule rictus01 2007 Annual Rideout 0 24-06-07 09:19 PM
