Old 16-11-06, 05:07 PM   #1
Default lowers on a pointy?
anyone fitted or removed the lowers on a pointy? how easy is it? do you have to use a fitting kit, brackets ect or does it just hold on to the radiator and frame?
Old 16-11-06, 05:11 PM   #2
To remove them, I recommend you ride into a van. HTH
Old 16-11-06, 05:11 PM   #3
muffles
i've fitted and removed these, it bolts to the frame and radiator using a fitting kit, the only part where it doesn't use a fitting kit is where it bolts to the upper fairing iirc.
Old 16-11-06, 05:17 PM   #4
so easy to remove then?
Old 16-11-06, 05:17 PM   #5
Old 16-11-06, 05:21 PM   #6
It's just advice, you don't have to take it BASAT certified, that was.
Old 16-11-06, 05:40 PM   #7
muffles
easy to remove the way i did it, yeah, but northwind's suggestion is probably quicker
Old 16-11-06, 05:44 PM   #8
Davido
Just bolts off, so do the brackets. But if you ever plan on putting them on again make sure you note how the brackets near the radiator were sitting, makes it easier to get it all lined up.
Old 16-11-06, 05:47 PM   #9
Old 16-11-06, 07:45 PM   #10
Alpinestarhero
No no, thats for the fairing UPPERS
Matt
Pointy lowers Lozzo For Sale - SV's and SV related items 0 31-12-08 10:34 AM
Removing Pointy Lowers Wadda SV Talk, Tuning & Tweaking 0 13-03-08 12:35 PM
Fairing Lowers (Pointy) booner SV Talk, Tuning & Tweaking 23 27-07-07 07:40 PM
Lowers for K5 pointy svrob SV Talk, Tuning & Tweaking 10 12-07-07 05:41 PM
pointy K6 red lowers hovis Stuff Wanted 0 09-07-07 10:19 AM
