Old 07-08-24, 05:31 PM   #1
EssEllTwo
Default SV650 clutch levers
Quick question on clutch levers for SV650's pre2010 models - do they not have the side stand cutout switch on them? I've just got a replacement lever for my 2014 SL2 only to find it has no noggin to press on the switch. On checking the fitment, it only lists up to 2009. If I select 2014 as my model year, no results for levers come back, hence why I took a punt on the 2009 lever.
EssEllTwo is offline   Reply With Quote
Old 07-08-24, 06:00 PM   #2
EssEllTwo
Default Re: SV650 clutch levers
Found the answer now by watching Tamsen Coopers video on fitting new levers to her curvy 650S - nope, they don't have the switch! ********. Time for a return.
Old 08-08-24, 11:20 AM   #3
garynortheast
garynortheast's Avatar
Not sure how the later models work, but on the curvy there is a clutch lever switch to stop you starting the bike in gear. The sidestand has its own separate switch.
Old 08-08-24, 09:05 PM   #4
EssEllTwo
Yeah, I used the wrong term there, there are separate sidestand and clutch switches to stop it being started in gear. The switch on the pointy is on the underside of the lever mount and there is a pokey down bit on the lever itself to activate it. The bottom of the curvy clutch lever is flat, no pokey down bit.
Stock lever:
https://shop-ps.pogliani.com/31809-l...v650-vx800.jpg
This one is for the earlier models so whilst it fitted, it didn't have anything to activate the switch:
https://www.sportsbikeshop.co.uk/mot...nt_prod/190174
replacement brake and clutch levers for gen3 sv650 rwe1 SV Talk, Tuning & Tweaking 3 23-11-17 09:16 PM
Pointy sv650 exhaust, indicator lenses, brake & clutch levers / shovel mudguard for sale Bash650 For Sale - SV's and SV related items 0 25-03-13 01:18 PM
Clutch Brake Levers for Suzuki SV650 03 - 10 ian505050 For Sale - SV's and SV related items 2 14-11-11 09:34 PM
Curvy Carbs, clutch levers and brake levers 21QUEST For Sale - SV's and SV related items 2 03-03-10 11:04 AM
Clutch levers? rob13 Bikes - Talk & Issues 6 01-11-07 06:30 PM
