Old 17-08-18, 04:41 PM   #1
minitwin
Default handlebar swap
I am struggling with the riding position on my S, so i've got a yoke and bars from an N.
I have the longer clutch cable, but do i need the throttle cables, or is it just a case of re routing them ?
Same goes for the switchgear wiring, is that just a re route for them ?
minitwin is offline   Reply With Quote
Old 17-08-18, 06:31 PM   #2
Default Re: handlebar swap
I found using my Gilles Vario bars that I needed longer throttle & choke cables. My bars are higher than the S, but lower than the N.
Switch gear was ok
Old 17-08-18, 06:36 PM   #3
minitwin
Switch gear was ok
thanks mate
Old 18-08-18, 12:40 PM   #4
might help if you tell us what year the bike is as the first and second gen bikes are different as regards to S/N such as throttle switchgear.
Old 20-08-18, 03:12 PM   #5
minitwin
Ah ! good thinking
It is an injected K6....
Old 22-08-18, 06:39 PM   #6
650
650's Avatar
N top yoke won't fit. Different offsets. You also need the lower triple.
93 VFR750 - WAY too many mods to list. Crashed
04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC
650 is offline   Reply With Quote
Old 26-08-18, 06:34 AM   #7
minitwin
The one i have looks identical - apart from the risers, and it's silver and not black...
Old 05-11-18, 08:12 PM   #8
minitwin
well, it's been a long time coming, but i've done it !
standard 'N' top yoke, drilled to accept fat bar risers, tech 7 fat bars, N clutch cable and venhill extended throttle cables
Old 05-11-18, 10:49 PM   #9
Adam Ef
Adam Ef's Avatar
Good stuff.
Did you need to change out front brake lines for longer too?
Old 06-11-18, 09:16 AM   #10
650
650's Avatar
Why have you drilled an N top yoke that already has risers...to fit risers? Am I missing something? Do you mean you drilled an S top yoke?
needs handlebar muffs agy Stuff Wanted 3 26-09-12 03:33 PM
Handlebar adjustment? SUPERSTARDJ01 SV Talk, Tuning & Tweaking 13 28-10-09 02:33 PM
HandleBar Swap? Renthal installation help ltlpit SV Talk, Tuning & Tweaking 3 29-07-07 01:02 PM
Handlebar alternatives.... Iansv SV Talk, Tuning & Tweaking 11 27-12-05 01:15 AM
oh to swap or not to swap that is the question.. DrPain Bikes - Talk & Issues 27 25-04-05 02:48 PM
