Old 28-10-18, 07:43 PM   #1
Barney626
Default Dashboard turn signal light always on, turns off when clutch is in
So here is an interesting one...
Sv650s K5 model
My right turn signal light on the dashboard is constantly on the 'low' setting (when you turn the signal on it still pulses high and low).
If you pull the clutch in, it turns off.
Any guesses how pulling the clutch in could affect dashboard indicator lights?
Barney626 is offline   Reply With Quote
Old 28-10-18, 08:18 PM   #2
garynortheast
garynortheast's Avatar
Default Re: Dashboard turn signal light always on, turns off when clutch is in
I'd guess at a short or a poor earth somewhere.
Old 28-10-18, 09:05 PM   #3
Have you got LED indicators? I think it is because the load is so low
Old 28-10-18, 10:08 PM   #4
Barney626
I have indeed. Came on the bike and I hate them because they are too dim to be seen in direct sunlight.
Only thing that's stopped me changing them is my bikes wiring is a little temperamental with loose connections. Previously had an issue with my sidestand switch relay tripping and making the bike cut out while I was riding it (Happened on an entry slip road to a motorway...)
Old 29-10-18, 07:23 AM   #5
Seems like a good reason to put stock ones on and sort out the bad connections
Old 29-10-18, 07:30 AM   #6
garynortheast
I'd second Darren here. Just go through all the connectors, clean them and treat them with ACF50 (hey, I've beaten RiffRaff to it there!).
While you're at it make sure your sidestand pivot is clean and greased so that the stand folds up properly. Some while back I let mine get a bit mucky and when I went over a bump, it was enough to jar it down a little but it was too stiff to fold itself back, and the sidestand switch then operated to cut the engine. A new return spring, pivot bolt, and some grease sorted it out.
Old 29-10-18, 05:51 PM   #7
Barney626
Recently cleaned up my sidestand mainly because it was so gunked up it wouldn't flick up by itself.
The issue I had was with the wire going from the sidestand into the relay box. the wire just came out of the box and it's impossible to properly put it back in because the 'clamp' for the wire was already crimped down...
Use the bike for commuting so can't risk messing with it now but once I put it away for winter might end up just totally rewiring that relay box. Previous owner made a total mess of the electrics on this bike, bits of loose electrical tape everywhere...
Old 30-10-18, 06:51 AM   #8
Nobbylad
Nobbylad's Avatar
Wiring looms are about £50 on fleabay. Might be worth the investment?
Old 30-10-18, 08:57 PM   #9
Barney626
Isn't replacing the loom a PITA?
Turn signal switch daktulos SV Talk, Tuning & Tweaking 2 05-04-17 10:20 AM
Turn signal and position light connectors? bellisan SV Talk, Tuning & Tweaking 2 24-02-13 11:11 AM
Front turn signal light (L) problem Slawuch Bikes - Talk & Issues 1 20-08-11 04:52 PM
Curvey SV turn signal/side stand relay diodes Zombie Jesus For Sale - SV's and SV related items 0 03-05-10 07:53 PM
SV650S AK8 Dashboard Light Disaster-Master SV Talk, Tuning & Tweaking 9 15-12-08 07:58 PM
