19-02-21, 01:23 PM | #2091 | |
Re: What have you tinkered with today?
A blocked pilot jet wouldn't allow any idling.
2016 SV650AL7 2023 GSX-8S |
19-02-21, 07:00 PM | #2092 | |
Getting it already for the bike trip this year, hopefully . . . . . |
19-02-21, 08:56 PM | #2093 |
Yes it is. Good point. I'll put the old one back in to narrow it down. I got the right plug and had to remove the small screw cap off the top to make it look like the one that came out and fit ok. I remember thinking at the time it was odd and wasn't 100% on how secure it felt.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
20-02-21, 03:13 PM | #2094 |
Fitted a new coil spring to my Mum's Audi A1. Not too bad to do, but a bit fiddly.
20-02-21, 10:17 PM | #2095 | |
I found the fixings could only be tightened under load and there was no mention of it in any of the instructions I could find, which prompted a 'take it all off again' and see what I've done wrong before reassembling and knocking it off the stands to try and see if that did the trick - I was pretty relieved when it did
21-02-21, 11:48 AM | #2096 |
They are a PIA as you have to compress the springs so much to get the strut in/out as the wishbone doesn't move that far.
I did see that under load you should be able to undo/tighten them - which is fine for the inner nut which is easy to access. But the main nut holding on to the car was impossible, unless you had a torx on the inner and a ratchet or deep ring spinner on the outer nut. I found the best way was to wrap the damper strut in a microfibre cloth and clamp it (lightly) with mole grips. Then i could hold the inner, whilst tightening the nut with a ratchet on top - was a lot quicker & easier. I wish i did this on removal as it would have been a lot quicker and easier! Only took a couple of hours overall which i was happy with. My own car had the Summer wheels/tyres put back on today seeing as this cold spell seems to be over for a while - cue snow showers at easter. |
21-02-21, 06:20 PM | #2097 |
Got the carb off the DRZ again, just to see if I got anything wrong last time I stripped and rebuilt it. Adjusted the float very slightly and gave everything a good spray in case any grit had got in there to cause the juddery ride problem. Soaked the jets and even though they looked clean I was suprised by the amount of dirt in the cleaning fluid after they'd sat in it for half an hour.
I wanted to check if I'd messed up the air / fuel mix when I put it back together last time. I definitely hadn't even touched it as the screw was totally seized in place. Ended up drilling a pilot hole in it and luckily getting a torx bit to hammer in securely and then screw out. Sourced an extended screw this afternoon and need to get it all back together tomorrow afternoon. I've got a two and a half hour speed awareness course to do online first though in the morning. Grrrr.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... Last edited by Adam Ef; 21-02-21 at 06:22 PM. |
21-02-21, 10:06 PM | #2098 | |
22-02-21, 05:15 PM | #2099 |
Ouch. To be fair my Mum's car is only 7 years old and done 40k miles, so the bolts were probably in a better condition. I also had the luxury of being able to soak everything in penetration fluid for a few days beforehand.
22-02-21, 07:58 PM | #2100 | ||
Test rode the DRZ. All good and great fun for half an hour then it got increasingly lumpy and erratic. Very off and on around corners and unless revved it wanted to stall. Didn't like constant throttle. I made a short video of what starts to happen once it's warmed up. 15 minutes more riding and it cut out totally and wouldn't start until it cooled for another 15 minutes. Then still wasn't happy on the ride home unless revs were kept high and varied throttle inputs. Only just made it home. I'm thinking igniton coil? Possibly fuel getting into the oil though apparently. I can't see why that would happen though?
