Old 04-12-18, 09:44 PM   #1
icecoke
Default a bit of info and help if can
just not long past my bike test and just got my self a 2002 sv650s all is fine with it exp from the rear brake light not working have had a look and found that the bottom end of the spring has come off that ok to fix
was looking over the bike and have fond that the oil has molecule in the engine is that the cyclender head gasket gone ? or somthing els and is it a easy job ?
and when it was running ideal there is a bit of popping coming from the exhaust
Old 04-12-18, 09:51 PM   #2
Default Re: a bit of info and help if can
Just replace the brake switch or reattach the spring.
Water in the oil? Has it been sitting around unused for a while. Check the radiator fluid level, is that near the level mark? Change the oil and filter first, doing a head gasket is a big job, and not one of the SV's usual problems. Mayonaise in the oil is usual if its been sat for a while, it'll go after a ride or two.
Popping when running is kinda normal, probably a gap in the exhaust if its had an aftermarket can fitted
Old 04-12-18, 10:05 PM   #3
icecoke
far i know it has been sitting for a bit
radiator fluid level is up to the top and clean
thanks for that am going to do a filter and oil change and plugs
yes there is a aftermarket can fitted the gap mite need fixed
hopping to get it done over the winter to get her on the road by April that when my inc runs out
thank you very much for the help
Old 05-12-18, 07:38 AM   #4
Don't worry about the gap between the can and the pipe, it won't do any harm
Fix it with this
https://rover.ebay.com/rover/0/0/0?m...2F252832535344
Old 05-12-18, 08:25 AM   #5
monkimagic
monkimagic's Avatar
As Mavizcap said. Only other suggestion on the popping is a vacuum leak on the carb boots. Worth getting the airbox off, check the rubber on the boots on the inlets and if they are not perished just make sure they are mated well and the jubilee clip is fine.
monkimagic is offline   Reply With Quote
Old 05-12-18, 08:30 AM   #6
icecoke
will have a look at then when i do the air filter
Any info on this SV? ZER0 SV Talk, Tuning & Tweaking 12 01-01-14 01:03 AM
Info on dole/dla, to live in my bros rented house ? Info please Joe Marcon Idle Banter 9 18-02-13 12:20 PM
Info please Dicky Ticker East Anglian Revolution 3 26-06-10 07:45 AM
CCC info Marshall SV Talk, Tuning & Tweaking 5 07-06-06 05:19 PM
Info please gc350 SV Talk, Tuning & Tweaking 0 14-07-05 11:20 AM
