Old 31-01-19, 09:17 PM   #21
glang
Default Re: TB sync issue
Gaz is it possible that the high reading is the correct one and the other the problem? If this was the case then low vacuum could be due to air leaks, poor engine valve adjustment, worn engine etc
Old 31-01-19, 09:46 PM   #22
Gaz.sv650
Gaz.sv650's Avatar
I'm not sure, the high reading is off the scale so that is never right at 1200rpm never used to be like that anyway.
The valves are due a check now on 30k they were well within spec at 20k.
Air leak would cause high revs?
The engine is using very little oil so hoping it's not worn.
Gaz.sv650 is offline   Reply With Quote
Old 31-01-19, 10:28 PM   #23
check the rear TB is in and on its inlet rubber properly and the clip is tightened up.
IIR there are two vacuum spigots on one of the TB's and i think its the rear or maybe not. make sure that the cap is not perished.
Old 31-01-19, 10:32 PM   #24
Gaz.sv650
Gaz.sv650's Avatar
Will try that a report back on the weekend.
Cheers for the help so far
Old 31-01-19, 11:00 PM   #25
glang
difficult to see what can give a high vacuum. I would have thought any air leak would reduce the vacuum and the only possible explanation is a restriction somewhere on the inlet side of the tapping point. For me an STV thats too closed would fit the bill perfectly....
When do you sync carbs? Vinc SV Talk, Tuning & Tweaking 1 23-04-13 04:59 PM
2008 sv650 clutch issue & abs issue my_galaxy Bikes - Talk & Issues 4 29-06-11 12:03 PM
Throttle Sync Yet Again I'm_a_Newbie SV Talk, Tuning & Tweaking 6 13-03-08 12:22 AM
Throttle Sync Again I'm_a_Newbie SV Talk, Tuning & Tweaking 0 16-02-08 04:39 PM
DVD out of sync. phil24_7 Idle Banter 7 16-11-07 05:50 PM
