Old 29-04-09, 12:20 PM   #21
sinbad
Default Re: Throttle body balancing
Ahh you're right, they're not circlips.
Thanks for the help, so to clarify though, we are talking about the short length of black tube which I used with the Carbtune right?
Old 29-04-09, 12:24 PM   #22
With carbtune you use 10cm or so or tube, then the damper (the small bore bit of clear tube), then a long tube.
You use that 10cm or so of tube or an approximation of it (one bit of tube isn't too different from another, the length doesn't need to be spot on exact)
Old 29-04-09, 02:12 PM   #23
ThEGr33k
Fair enough. Must confess ive not done ballancing on the SV, done it on a couple of other bikes though. How boring is the SV?
Throttle body synchronisation K3 muzikill SV Talk, Tuning & Tweaking 23 23-01-08 06:35 PM
Balancing Carbs/Throttle bodies tomjones2 Bikes - Talk & Issues 6 06-07-07 10:07 AM
Throttle body balancing Caddy2000 SV Talk, Tuning & Tweaking 6 18-05-07 06:22 PM
Throttle balancing - Friday night job? BillyC Soho Massive 15 15-04-05 04:36 PM
Throttle body diameter danci1973 SV Talk, Tuning & Tweaking 1 05-12-04 11:34 AM
