Old 15-06-24, 07:02 PM   #1
Kenzie
Kenzie's Avatar
Default Anyone any good with electronics and battery voltages?
I just picked up a Panasonic camcorder and have been looking for some aftermarket batteries. The original spec is 3.6v but most of the ones I've seen are 3.7v. Is this likely to be an issue? They say they are compatible.
Sent from my Nokia XR20 using Tapatalk
Old 15-06-24, 07:50 PM   #2
redtrummy
Default Re: Anyone any good with electronics and battery voltages?
90% plus you will be ok.We use rechargeable for nearly everything not had a problem. 0.1v as a percentage of 3.7 not worth thinking about. I would work it out but post stroke confusion makes it hard to concentrate.
redtrummy is offline   Reply With Quote
Old 15-06-24, 07:57 PM   #3
Kenzie
Kenzie's Avatar
Cheers. The listing says it's compatible, I would think the onboard circuitry would allow for slight variation in battery voltages.
Old 15-06-24, 08:19 PM   #4
Kenzie
Kenzie's Avatar
Can I also ask about chargers? The charger that came with the camera has an output of 4.2v, loads of others on Amazon also output 4.2v, would these be ok? It's an Ex Pro Charger with the correct mount and connectors for the camera.
Old 16-06-24, 08:16 AM   #5
redtrummy
should be ok.once its changed it should shut down stopping over charging
Battery voltages Chris_SVS Bikes - Talk & Issues 27 26-10-17 08:14 PM
What should a good battery voltage be? SVspeedr SV Talk, Tuning & Tweaking 62 22-08-16 05:27 PM
Anyone good with electronics? Panasonic stereo Kenzie Idle Banter 5 08-10-14 06:39 PM
Is it a good idea to charge your battery..... Tigerrrr....... Idle Banter 2 12-01-11 12:06 AM
