Old 07-08-15, 09:49 PM   #1
LewSpeight
LewSpeight's Avatar
Default Can i do a handlebar conversion with what ive got?
I'm on a semi faired / bikini model early 07 SV and have the handlebars and forks off my old NAKED 06.
Could i swap over the yokes, lower fork crown, and put my bars on, connect all the switch gear and clutch/throttle cables and away we go? Or do i really NEED to buy longer brake lines and cables?
and if i gotta buy new cables, will they all still plug into the switch gear and throttle assembly things?
Thanks, sorry if i sound simple.. just gotta make this bike comfier!
Old 07-08-15, 09:51 PM   #2
Default Re: Can i do a handlebar conversion with what ive got?
you dont need new switchgear cables you just need to remove the connectors from the securing bar in front of the airbox. yes you need new brake lines.
Old 07-08-15, 09:58 PM   #3
LewSpeight
LewSpeight's Avatar
New brake lines and im good to go!?
Will i need to buy new grips? (obviously never done this before)
Old 08-08-15, 07:56 AM   #4
Grips, carefully slide a thin screwdriver in between the grip and squirt some WD40 or similar and wiggle the screwdriver so that the wd40 gets everywhere, the grip should slide off easily.
clean it up and dry it.
to reattach spray hairspray inside the grip and slide it onto the bar. The hairspray will stick it to the bar nicely.
do the same for the throttle side
Curvy S to N handlebar conversion steve-sv SV Talk, Tuning & Tweaking 2 22-02-15 01:18 PM
Handlebar conversion steve-sv SV Talk, Tuning & Tweaking 2 15-01-15 01:59 AM
LSL handlebar conversion gazza For Sale - SV's and SV related items 0 27-04-12 06:50 PM
handlebar conversion chamiakmako For Sale - SV's and SV related items 0 19-05-11 03:54 PM
Handlebar conversion SAMMY650 SV Talk, Tuning & Tweaking 21 08-03-08 03:14 PM
