Old 31-03-23, 01:38 PM   #31
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Carb vacuum
Could it be a duff petcock even if new ?
Also check for any fuel in the engine oil.
Old 31-03-23, 02:04 PM   #32
GDBD59
Petcock.....maybe? It's just occurred that if I apply a vacuum, I can check the outlet.
I did have fuel in the oil before, but since buying the carb bits & getting the float heights set, that's been fine. Worth a check though.
GDBD59 is offline   Reply With Quote
Old 31-03-23, 02:13 PM   #33
R1ffR4ff
R1ffR4ff's Avatar
I've just remembered. I used a Petcock same as yours but I hacksawed off the bulbous end of that fat pipe so I could slide the fuel pipe I was using on and then secured it with a screw-tight fuel pipe clip.
Old 31-03-23, 02:18 PM   #34
GDBD59
It does fair-swell the hose up....I'll consider that.
Old 31-03-23, 02:24 PM   #35
R1ffR4ff
R1ffR4ff's Avatar
Neoprene fuel pipe isn't expensive. I renewed all mine in ,"Lockdown". I bought some 6mm ID pipe and some 8mm ID pipe so I could mix and match where needed.
I prefer the non-reinforced type,
Soft Rubber fuel pipe eBay
Hose clips choose to suit
Old 31-03-23, 02:44 PM   #36
GDBD59
Ditto. One of mine was Nitrile.
Twinmax Electronic Carb/Throttle body Vacuum Balancer Bibio For Sale - Other Bikes and General biking items 3 03-05-21 12:12 PM
Carb vacuum lines extended - problem. bigchris SV Talk, Tuning & Tweaking 5 01-01-11 09:55 PM
Carb balance question-applying vacuum Old Git SV Talk, Tuning & Tweaking 9 07-07-09 11:51 AM
vacuum gauges - carb synching (k2 naked BS) ejohnh SV Talk, Tuning & Tweaking 9 13-12-06 06:43 PM
carb vacuum guages 01 sv650s SV Talk, Tuning & Tweaking 1 08-11-06 08:51 PM
