Old 14-07-18, 01:12 PM   #61
BigTon
Default Re: Erratic ignition now no power, no start
if you fitted a decent mosfet RR and it went pop then i would seriously be looking at the stator AC output.
That’s what I was thinking
What should it be?
Old 14-07-18, 01:29 PM   #62
R1ffR4ff
R1ffR4ff's Avatar
What should it be?
70v AC @ 5,000 rpm
Old 18-07-18, 07:14 PM   #63
BigTon
Originally Posted by Seeker View Post
...between yellow wires 1-2, 2-3, 3-1
I’m getting 80v @5000 rpm
Old 18-07-18, 07:29 PM   #64
Biker Biggles
Biker Biggles's Avatar
All three the same or very similar?If so I think that is OK.
Old 18-07-18, 07:31 PM   #65
BigTon
They’re all the same. Manual says 60 so not sure if 80 is too high?
Old 18-07-18, 07:46 PM   #66
R1ffR4ff
R1ffR4ff's Avatar
I was mistaken when I posted my 70 VAC as mine is the 300w Stator on the Curvy.The,"S" versions I believe use a 275w Stator.
Is it possible some one has upgraded the Stator to a higher powered one?
Old 18-07-18, 08:07 PM   #67
as long as all three outputs are the same and MORE than 70VAC and less than 90VAC you have a healthy stator.
the more voltage the stator kicks out the more the regulator has to work so produces a little more heat.
contrary to popular belief its actually bad to run the bike without your lights on. you want to use as much power as you can without sacrificing charging/ignition system. once a battery is fully charged it should only need a trickle from the RR to keep it healthy.
Old 18-07-18, 08:11 PM   #68
BigTon
Good to know thanks. Maybe I’ll fit some heated grips to use up some power
Old 20-07-18, 12:18 AM   #69
Yellow650Loz
I think there's a few here mistaking voltage for current.
If the voltage drops then the current draw will be higher.
I.e.
55w @ 12V DC = 4.583 Amps
That's basically one headlamp bulb on a battery and engine off
55w @ 14.9V DC = 3.691 Amps
That's the same bulb but this time the battery is charging....the engine is running.
It's the current that overheats wiring and connectors, not voltage.
Now it could have been a corroded connector that's caused voltage drop and so the current draw has increased. However, I would be cautious as to why it melted in the first place, jump starting a motorcycle from a car is fine. Running or otherwise.
Please don't ever try jump starting a car from a motorcycle though!!!!!
Old 20-07-18, 06:45 AM   #70
BigTon
I.e.
So a faulty battery could cause a increase in current and melt wire/connector?
Pointy sv, no power on ignition Dave20046 Bikes - Talk & Issues 9 05-08-13 07:31 AM
Bike wont start. (ignition doesn't throw an error code) stamford Bikes - Talk & Issues 6 03-08-09 12:49 AM
Erratic idle cat0020 SV Talk, Tuning & Tweaking 11 22-10-08 08:36 PM
Curvy - Ignition controlled electrical power source under pillion seat? TheStudent SV Talk, Tuning & Tweaking 12 02-10-08 06:01 PM
other cams and ignition advancer => less power... r4ce_e3nd SV Talk, Tuning & Tweaking 11 02-09-06 09:05 AM
