Old 08-10-12, 02:32 PM   #41
CodeJACK
Default Re: SV special build - S-pokey-V.
Found the link. The TL1000S frame is in proportion to the curvey i think but your right, this guy did use a Rotrex charger.
http://www.tlzone.net/forums/perform...ger-build.html
CodeJACK is offline   Reply With Quote
Old 08-10-12, 03:29 PM   #42
That was built as a hill climber for Scarborough.
TSM might be able to help with who did a road going Super TL
Old 08-10-12, 06:14 PM   #43
millemille
I've seen Sam's bike in the flesh and on the net and it is very nicely done - but I'm not forking out for a Rotrex charger.
The only reason I got thinking about supercharging was because I found an Eaton M45 charger in the workshop that I forgot I had and wondered whether it would feasable to use to make the SV angry....
It's too big - about 3x times larger than the Rotrex unit Sam used - and weighs about 8kg.
Besides, I'm guilty of getting carried away; I did say at the beginning of the build that I wasn't going to do anything to the engine until I'd made sure that the single disc up front could cope with what was being asked of it with a standard engine propelling the bike. No point getting more power if it means I'm going to be punching SV shaped holes in hedges....
millemille is offline   Reply With Quote
Old 25-11-12, 07:18 PM   #44
millemille
Not massive mounts of progress to report due to being waaaaay too busy at work and having 2 wisdom teeth extracted....
Swingarm is finished - bead blasted and then scotchbrited and now ready for setting up the rear linkage for designing, machining and welding into the frame...
Bought a set of GBmoto rear sets - very nice an excellent value for money but unfortunately they don't kick the pegs out far enough to give the clearance needed around the swingarm for the exhaust routing. So I'm popping over to see Ivan & Jamie Porter (of supermono racing fame) to have them machine me up a set of offset matrix plates for the rearsets.
I've been attacking the petrol tank - cutting out the original filler cap recess in preparation for plating it over to mount a Monza stylecap and also cutting out the back ready to weld in the fuel cell that is going under the seat and replacing the rear sub frame...
Old 26-11-12, 01:16 AM   #45
Jayneflakes
Jayneflakes's Avatar
Magnificent work Sir, do please show us more.
Jayne you're a Pussy Magnet
Old 26-11-12, 09:44 PM   #46
You make my workshop feel inadequate
Old 26-11-12, 10:24 PM   #47
sam anon
Looking great, I wish I had a garage, even for routine maintainence!
Old 03-12-12, 12:36 PM   #48
speedyandypandy
I love great builds like this, keep up the great work.
Old 05-12-12, 12:00 PM   #49
650
650's Avatar
Got a boner for this thread, just sayin'
650 is offline   Reply With Quote
Old 06-12-12, 10:16 PM   #50
savage86
Oh why was i not blessed with talent/temperment to do this. Oh well the good looks will have to do
gsxr build sv650nutter149 Thames Valley 21 12-05-10 07:22 AM
Hello! I have a few questions regarding a special build. NcSv SV Talk, Tuning & Tweaking 50 08-09-09 11:47 PM
For Hovis-Gid-Stretchie-Wideboy , just a special thought for you guys on this special day xXBADGERXx Idle Banter 21 24-07-09 04:26 PM
About to build one of these SV-net Idle Banter 14 22-11-08 04:14 PM
VW build quality kwak zzr Idle Banter 17 03-12-07 09:44 AM
