Old 14-09-15, 12:19 PM   #1
Grinch
Default SV1000: Things to do.
So I've got this SV1000, and I have a list of things to do, but does anyone else have experience of this or something they think I should be doing?
  • Check wiring from stator to reg/rec and prob replace from reg/rec to direct battery as the connectors can burn up as mine did
  • Green connector is a must you don't want that one going wrong (need to find out what this is).
  • Testing the stator is a good idea.
  • Clutch basket mod is another good idea (need to look this up).
  • Cloudy clutch fluid seems to be a common problem but not always the first culprit, many say replace the seals on the slave cylinder but I found my cloudyness was actually from the line, replaced to stainless and problem solved (Its got braided hoses, but I'm not happy with the 3 line system).
  • Tre is a nice simple mod but if you got the cash a gipro gear indicator with built in tre is a nice alternative (Anyone used a GiPro before?)
  • Add a switch for dealer mode - comes in handy (is this just to get the warning codes up?)
Old 14-09-15, 03:34 PM   #2
Default Re: SV1000: Things to do.
strip and service the brakes
service the forks and shock
check the headstock bearings
check the swingarm bearings
Old 14-09-15, 04:10 PM   #3
Ask Skip, but one of his mods was to fit a Power Commander and get it mapped.
Smooths out the power delivery and makes it a much more pleasant bike to ride.
don't know if a custom map would achieve the same, for less money?
Old 15-09-15, 10:51 AM   #4
Grinch
I've seen a plug in mod that smooths out the power delivery - http://www.healtech-electronics.com/products/xtre/
Along with the GIpro, which is a gear indicator with TRE mod.
Old 15-09-15, 03:36 PM   #5
Skip
Skip's Avatar
Power Commander is nice but not really a must - I was just used to a Honda Blackbird so after than the SV1000 felt a bit lacking lol
In my grand old age now I would channel my funds into nice suspension
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 15-09-15, 04:35 PM   #6
Mark_h
Mark_h's Avatar
^^ This ^^
PLUS Balance your throttles, then balance them again then once more for luck. Runs like a 3 legged donkey if they are out. A bloody quick donkey but still lumpy. Balance around the interestign moment you get around 3k.
As for all the other stuff, I've never had to do any of it. Maybe it'll go up in flames next time I ride it but I'd recommend spending your time riding it and balancing your bodies instead.
Minister for Sustainability
Old 16-09-15, 10:42 AM   #7
Grinch
Wondering if I can find a Power Commander anywhere for a keen price.
Old 16-09-15, 05:53 PM   #8
tonyt
Ebay...!!!
tonyt is offline   Reply With Quote
Old 17-09-15, 09:04 AM   #9
Grinch
Yep, seen them on there, about 300 is the best I can see for the latest model. About half that for a second hand or salvaged one, though they all seem to be from the states.
Old 17-09-15, 09:08 AM   #10
Skip
Skip's Avatar
I bought my Z750 Power Commander from the States second-hand - worked a treat and much cheaper than I could get one in the UK.
'81 Honda H100A
Gsx/gsxr/sv1000 wheel to fit my 2006 sv1000? Niall_farley Bikes - Talk & Issues 10 05-05-14 05:08 PM
They're there with their things. garynortheast Idle Banter 12 17-12-12 10:23 AM
shiny shiny things for my new sv1000 davepreston SV Talk, Tuning & Tweaking 41 24-03-10 10:32 PM
Things to do... rubberduckofdeath Pennine Massive 1 27-02-08 08:24 PM
Things you say... Stingo Idle Banter 14 18-10-06 02:24 PM
