15-10-17, 08:47 PM | #11 |
Re: Anyone got FZ6 Fazer experience
Had an SV for 40k miles. Had upgraded rear shock, lower pegs, bar conversion, tall screen gel seat and loads of other stuff that's not really relevant to your question.
Now have a 2007 fz6 s2 and have done 12k miles on it so far, commuting and touring. Only modification is chucked the standard bars and put slightly wider renthals on. I would have the SV back in a heart beat. The Fazer is comfortable but no more comfortable than the tweaked SV. The Fazer is boring as hell. It's much faster but it makes it's power in a very liner way all though the rev range and has very little torque. The result is having to keep it around 10k-12k rpm which is screaming its tits off. Around this rpm it is vibey and the reflection in the mirrors is just a blur. Working on it is more fiddly with some things looking like a real after thought on yamahas part. For example, to remove the front sprocket cover to clear out crud you have you must remove the gear linkage that runs through a gap in the frame. Undersea exhausts cost a fortune unlike the millions of cheap SV options. The standard can sounds crap. Headlights are the annoying one light for dipped and both on for hi beam so people keep flashing you to tell you you have a bulb out. Good things are they are pretty comfortable as stock. The brakes and front forks are FAR superior to the SV. It is really well balanced out of the box and handles well with none of that swing arm play the SV has. I only use a bike to commute these days so the fazer is fine but if I ever go riding for fun again in the future I'll need to chop it in.
"Somewhere between happy and total f**kin wreck" |
15-10-17, 09:57 PM | #12 |
Cheers for the input. That's a pretty enlightening review!
(+ You know there's a fairly simple mod to have both lights on at once? One piece of wire connected allows the low beam to work on the bulb that otherwise only has it's high beam wired in.) |
16-10-17, 08:57 AM | #13 |
The street triple ergonomics are immediately sorted with a sargent seat. I speak from experience. Wider and flatter pan = not crushing your balls on the tank.
The over-the-bars position is where you want to be on a sharp bike. Upright and beg is comfy, but hardly makes for an involved, fun ride.
93 VFR750 - WAY too many mods to list. Crashed 04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC |
Value of '98 Fazer and '06 YBR-125? | dill89 | Bikes - Talk & Issues | 1 | 23-08-10 08:51 AM |
My new Fazer 600! | metalangel | Bikes - Talk & Issues | 12 | 14-09-09 11:50 AM |
new fazer? | Quiff Wichard | Photos | 14 | 07-08-07 11:20 AM |
Fazer S2 | New Leaf | Bikes - Talk & Issues | 6 | 05-07-07 12:06 PM |
FZ6 Fazer | Rog | Bikes - Talk & Issues | 14 | 14-11-06 11:14 PM |
