Junior Member
the ignition lock on my SV has always been a bit hard to get off the steering lock and recently got worse moving from on/off positions. I always kept the lock clean and lubed up. after taking the lock off and stripping it down I found the cause. when you insert the key it pulls the 8 protruding pins down into the barrel so the barrel can turn, this was not happening on the last few pins unless you lifted the key in it's slot. I used a mini bench grinder to carefully grind the pins down a little bit; tricky as they are spring loaded so you cannot push on them. anyhow, now when i put the key in all pins are flush with the barrel. after a bit of oil and putting it back together it feels like a new lock! well happy
SV650 naked plodder! ![]() |
wrong section.
but yes your right. i documented this years ago. |
Junior Member
whoops, sorry ok wrong section, new to these forum things, just so pleased at fixing this nagging fault, I wanted the world to know!!
Thread Tools | |
Ignition key wiggle solved | Bibio | Bikes - Talk & Issues | 21 | 09-07-15 08:19 PM |
Sticking igntion lock. | 650 | Bikes - Talk & Issues | 4 | 05-07-12 10:29 PM |
Ignition Barrel Sticking | svdemon | SV Talk, Tuning & Tweaking | 4 | 31-03-09 05:32 PM |
ignition lock, seat lock, and key | adam_castell | For Sale - SV's and SV related items | 0 | 27-02-07 07:56 PM |
Sticking ignition lock | neilhatch | SV Talk, Tuning & Tweaking | 20 | 14-04-06 08:45 PM |
