I know I don't have an SV any more, so mod's please move this elsewhere if need be. but my I bent my key in my 2004 cbr600rr's fuel tank whilst filling up....
![]() thanks for any help and advice.
AR08 - QUALITY! AR09 -QUALITY! AR10 -QUALITY! AR12 -QUALITY! AR13 -QUALITY! 650s '52 curvy in yellow was my baby ![]() cbr600rr: Mivv exhaust (with a baffle that's gone missing in action.... ![]() ![]() |
yes the new key needs programmed. this can sometimes be done via the ignition but usually requires a machine. sometimes there are removable transponder chips on the key fob.
Thanks bibio, looks like I will have to swallow this one and take the pain from the thieving bar stewards! 😡
I had similar with getting a Spare car key cut.Luckily my MOT guy knew a small local non dealer garage that made one for £60 compared with over £150 elsewhere.
Ring some local small independent bike garages/shops and see if they know anything. HTH ![]()
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." |
If the chip isnt transferrable you could fix the old key (minus the metal bit of course) somewhere hidden on the bike and, assuming its a standard type, just get a new key cut. You would lose the security afforded by the transponder but, if you get several cut, need never worry about the problems of losing the key......
Or just put the remains of the old key on the ring with the new key?
Dealer is wrong.
All you need to do is get the right key blank, get it cut and transfer the transponder. Total cost probably under £15. I really get cheesed off with dealerso knowingly(more than probable) trying to fleece folks. https://www.youtube.com/watch?v=Yk21gcxxcCs Don't forget to glue the cover after transfering(as mentioned in vid) transponder. |
#8 | |
Thanks for that ![]()
#9 | |
thank you kindly for that! now, will my stealer sell me just a blank uncut key?
#10 | |
I have also just tried this technique of removing said chip from the key and the "chip" itself has broken a little bit. do you know if this will affect it's then being put into a bank key?
Thread Tools | |
Broken down | hongman | Idle Banter | 36 | 16-06-11 07:01 PM |
Help I'm broken down! | YellowMonkeyBoy | SV Talk, Tuning & Tweaking | 19 | 17-03-11 06:26 PM |
Broken down | richiekuk | Bikes - Talk & Issues | 20 | 24-12-09 05:41 PM |
Startrek.steve broken, SV650 broken too | startrek.steve | Bikes - Talk & Issues | 31 | 26-08-08 12:49 PM |
Broken dreams and broken lives. | Peter Henry | Idle Banter | 7 | 15-09-06 07:43 AM |
