Old 26-09-23, 12:18 PM   #1
glang
Default SV650S Fork leg bottom bolt leak
Im really struggling to get the bottom bolt (the one that holds the internal damper tube in place) to seal. I took out both damper tubes and on one fork the bolt sealed straight away using the old copper washer. However the second has been much more difficult and now has a new washer but is still weeping fork oil even though Ive tightened it a couple of times!
Old 26-09-23, 04:18 PM   #2
garynortheast
garynortheast's Avatar
Default Re: SV650S Fork leg bottom bolt leak
Have a look at the area in which the washer sits on the fork leg to make sure it's clean and free of rough patches or imperfections.
Old 07-01-24, 05:22 AM   #3
glang
Just to close this thread, it wasnt the bottom bolt leaking but the fork seal, doh! Anyway all done (although with a cheapy replacement..) and dry again.
Old 07-01-24, 02:52 PM   #4
garynortheast
Ah, good to read about,a satisfactory conclusion to this.
Old 07-01-24, 03:39 PM   #5
glang
Yes my eyes keep wandering to CBR500Rs or 660 Tiger Sports but the old SV just keeps on and really does everything I need although it is looking a bit worn now especially after spending 5 days under water in my garage in 2019...
Old 09-01-24, 03:29 PM   #6
R1ffR4ff
R1ffR4ff's Avatar
Same here. Every now and then I keep thinking of getting an SV1000 as the SV650 is the biggest bike I've owned but then I get on the SV650 and that smooth torque and sheer ,"Throwabailty" and the thoughts pass-away
Old 10-01-24, 09:20 AM   #7
glang
I dont think you would find the SV1000 nearly as slick as the 650 both in terms of vibration and gearchange...
Old 10-01-24, 10:03 AM   #8
R1ffR4ff
R1ffR4ff's Avatar
That's what I have seen in posts. The SV650 has been the perfect fit for me. I have some shoulder/neck and muscle problems so a heavier bike could well be a chore at my age. I love the ease with which I can control the SV and the engine braking coming into sweeping bends is a constant joy to me along with it's other attributes
Old 10-01-24, 04:44 PM   #9
fun fact about the SV650 weight. its heavier than the GSX-R 750 K4. its just the the SV distributes the weight a bit better.
always had a hankering for a GSXR 750 with a comfort kit
Old 18-03-24, 05:43 PM   #10
Toooldtodie
Toooldtodie's Avatar
Wouldn't the GSX S750 be that kind of beast?
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Kawasaki 636 BH1 rear shock bottom bolt part number? Pricey12 SV Talk, Tuning & Tweaking 6 09-04-13 09:50 AM
Help, I've screwed up the bottom shock bolt hongman SV Talk, Tuning & Tweaking 123 06-09-12 04:28 PM
Help! Someone else has (possibly) screwed up the shock bottom bolt! dirtyred619 SV Talk, Tuning & Tweaking 20 27-08-12 09:01 PM
ZX9 or 10 bottom suspension bolt DaveW_42 Stuff Wanted 0 21-05-10 11:29 AM
Damper Bolt For Fork, sv650s 1999 curvy cudd SV Talk, Tuning & Tweaking 7 24-08-07 11:03 PM
