Old 28-04-06, 11:47 PM   #1
Joe110
Default What amount and weight fork oil is in the SV650 2004 model?
Cheers Joe.
Old 29-04-06, 12:46 PM   #2
Gnan
i think it's 475ml and 15W but not sure (!)
Old 29-04-06, 01:08 PM   #3
Cloggsy
Default Re: What amount and weight fork oil is in the SV650 2004 mod
Cheers Joe.
It depends on your weight, what springs you are using & all sorts... If you are keeping the original springs, & putting heavier oil in, the the volume may be the same... But I ain't sure TBH...
PM 'elmerfud,' (or indeed 'Mrs Fud',) He's the Pennine Massive's suspension & forks expert
Old 02-05-06, 05:41 PM   #4
vincerhodes
Yeah i'd try a few different settings if I were you, 15w oil should be thick enough but try changing the volume/air gap to see what suits you, as long as you use the book value as a guide you'll be in the right area (not sure what that is for your model and theres no haynes manual about yet)
Hope this helps
Wanted seat cowl for blue SV650 2004 model Joe110 Stuff Wanted 3 31-10-11 09:00 AM
gsxr front fork springs, rider weight Bibio SV Talk, Tuning & Tweaking 32 19-10-08 12:24 PM
WANTED complete wireing loom for 2004 model sv650 sv650k4 Stuff Wanted 3 21-12-07 05:30 PM
Fork oil weight. Jase22 SV Talk, Tuning & Tweaking 6 06-06-06 03:58 PM
Fork oil weight kern0079 SV Talk, Tuning & Tweaking 21 30-04-05 05:11 PM
