Old 16-06-11, 05:35 PM   #1
al88
Default Grinding when first starting out
Hey SV'ers,
I have a weird issue. When I first start out, upon letting out the clutch with the throttle held open, it grinds, it feels like the chain is slipping, but its not. It makes a grinding noise then once I'm off the rest of the drive goes great, no other issues or funny noises at all, and it has great throttle response. Any ideas?
Old 16-06-11, 05:39 PM   #2
tinpants
Ubique
tinpants's Avatar
Default Re: Grinding when first starting out
fubar'd clutch. Or almost fubar'd
Jesus loves you. Everyone else thinks you're a pillock
tinpants is offline   Reply With Quote
Old 16-06-11, 08:44 PM   #3
would agree with that sound like your almost on the steel plates
Old 16-06-11, 10:40 PM   #4
Mine does this, I haven't yet fathomed it as I've had the bugger in bits a few times and nothing seems bent, warped or worn out.
It seems to coincide with a grab which slides the back tyre a quarter turn or so. I am thinking it is notched basket that hangs then releases and chatters, thus explaining the grab and the screaming noise.
Old 17-06-11, 05:44 AM   #5
mister c
mister c's Avatar
Mine used to do the same. I replaced the clutch plates & all is now well
Grinding Rear Brake sp07tjwh SV Talk, Tuning & Tweaking 19 02-02-11 12:13 PM
grinding noise Wideboy Idle Banter 11 06-08-09 01:59 PM
gears grinding KillaSV SV Talk, Tuning & Tweaking 1 16-03-08 07:39 PM
Baph goes peg grinding... Baph Bikes - Talk & Issues 24 12-04-07 05:46 PM
Grinding 1st!! Spider SV Talk, Tuning & Tweaking 9 02-01-07 02:50 PM
